Results 11 to 20 of 30
Thread: Auto power off
  1. #11
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Post
    Originally posted by accord:
    <STRONG>Yes, it is VERY!! important to properly shutdown the computer. It might be ok to force shut off computer few times. But if you keep doing that it will cause several problems. such as :
    1. The opened programs might lose its settings and files.
    2. Windows system files will get corrupted(it will fix by scandisk, but if the computer keeps improperly shutdown, the files can not be fixed. you have to reinstall windows)
    3. the most importantly, if the hard drive keeps shut down improperly, it will have FAT files(the hard drive tracks will be corrupted) and the hard drive can not read files. If you have too many FAT files , the computer will not recognize the hard drive, if this thing happens, you are screwed
    Only low level format will fix this problem but if you have too many FAT files, you just have to throw the hard drive. The hard drive is just like a record player , the reading sensor will stop when power got shut off, when the power is back on, it will scratch the disc to move back to staring point.
    Even if you are using DOS , you need to shut down the hard drive properly . Old DOS program used to have shutdown.exe file but I am not sure about windows' DOS.
    These are why it's important to shut down properly.
    </STRONG>
    Very little of this makes sense.
    True, some programs may lose their settings. However, the FAT is the File Allocation Table, and all DOS and Windows (except NT) systems to keep track of files and their location on the disk.
    As for scratching the disk by turning it off improperly, these days it not a problem. All drives made in the last 15 or 16 years have been auto parking. Older drives (ie. 20MB MFM drives) needed to be parked via a software utility, but new drives do not have this requirement.
  2. #12
    Mar 2001
    Cincinnati, Ohio
    Post
    Accord: You are so full of crap its coming out your ears and onto the floor.
    There is nothing you can do to a HD that can't be fixed with a High-level format, besides dropping it on the floor. You can't even do a Lowlevel format on a drive, it had to be done once, and at the factory.
    There is no problem with turning Dos off without shuting down, I didn't even know there was a special way to turn it off, and I have been using it for years.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
  3. #13
    Nov 2000
    Chapel Hill, NC, United States
    Post
    I tend to disagree lstrunk, I've found a few bad sectors on my hard drives after improperly shutting down, and those could not be fixed with a format. I then had 150 mb of unusable space on my HD.
    Got started with computers on this board early in high school...now I run a web development company and am about to build my dream machine.
  4. #14
    Mar 2001
    Cincinnati, Ohio
    Post
    Datman: That was most likely not caused by an improper shutdown, it was probably an error in you disk that was caused at the factory, and then decided to show up when you did a scan-disk after an improper shutdown.
    Have you tried reformatting?
    IF that still doesn't work, send it back to the manufacturer if its still under warranty.
  5. #15
    Apr 2001
    Madison, WI
    Post
    Man! Guys, let me clear this for you.
    First of all. I'm NOT full of crap!
    I've been a programmer since DR-DOS days(before MS-DOS came out).
    And yes just like someone says FAT is not a file it's File Allocation Table, it's just when the FAT got corrupted, we used to call it you got FAT Files. )
    And old hard drive need to be parked before it shuts down. And I heard that (not exactly sure) new HD has been improved but I don't know how it exactly got improved (I'm not a computer engineer, if there is a computer engineer , please explain this).
    But ONE THING IS FOR SURE, when the power get shut off while HD is being read or written, YOUR (new or old) HD FAT WILL BE CORRPUTED! you might not notice it right away but it will cause other problems!
    and Windows constantly read and write files on your HD (Even when you are doing nothing, it's b/c there are background running programs and also windows system files.)
    SO when you just shut off the power, chances are you are shutting down the power while HD is read or written!!
    and for 'lstrunk' if you don't know anything ,just shut up ok?!
    let be technical here, technically windows format is NOT A FORMAT, it's amost like just deletting files, This CAN BE recover , actally there are programs out there that recover formatted Hard drive or disk! Old Dos had unformat.exe and undelete.exe files. look for internet for these files.
    And there is DOS format which you CAN NOT recover , b/c it's totally erase all files from your HD or DISK. but not back to factory setting.
    and with low-level format you can make HD back to factory setting. a lot of now days bios have low level format program, or this disk with when you buy new HD, it has low-level format. Old dos used to have low-level format program too, but I'n not sure about windows dos. windows still run base on dos but they don't have all old dos progrmas. but I think they still have low-level format programs, I think I used once before (I'll find out and tell you later.) and you can always get it from internet
    and 'lstrunk' if you are so sure you can not low-level format your HD, why don't you try it? huh? You will have fun reinstall all programs.
    and for those who force shut off the computer several times in a day, try to run norton disk doctor(you can download this for trial) You can see how many bad sector you have in your HD (I'm not saying these are all cause by improper shutdown , there are a lot of problems cause this, program crash, virus, etc, but one of the major cause is by improper shutdown!!!)
    and then try to format your hard drive and rerun the NDD (norton disk doctor), in first site, it looks like you don't have any bad sectors but as ndd check your HD , you will know that the bad sectors are still there.
    try this "lstrunk' if you are so sure that windows format WILL FIX ALL the problems.
    (by the way NDD reloacte the files from bad sector to good sectors, so run this program often)
    if you have too many bad sector(FAT), it will cause a lot of problems such as speed reduce, crash, sometimes it will give error message when you try to open files, and major problem will be the computer will not recognize the hard driver.
    I'm telling you these base on my personal experience, I threw a lot of HDs b/c of bad sectors. in matter factor this is number one reason of damage Hard drives.
    I'm sorry for lonf message but it makes me mad when the people like 'lstrunk' say like they know so much when they know NOTHING.
  6. #16
    Jan 2000
    Exclamation
    Keep it friendly guys, or I will close this topic.
    Accord: New drives have a return spring (or sometimes small magnet) that returns thead to parking position after power is cut. A latch then locks the head in place.
  7. #17
    Aug 1999
    Yorba Linda, CA
    Post
    Accord - when I first read your post, I had a very hard time seeing what you were trying to say. When you use terms like "FAT Files" which you mentioned are from the DOS days, many of us might not get what you were trying to say. Also, I don't understand how you make the link between the FAT being corrupted and the hard drive being unuseable. The FAT is strictly an OS-managed area of the disk. It has nothing to do with low-level hard disk operation.
    Let me clear a few things up:
    1. Hard disk scratching: There is no way you can possibly physically damage a hard disk except by some physical means (i.e. dropping or banging on the drive). The heads inside a hard disk are suspended above the disk. They will never touch the disk during operation, even during an improper shutdown. The only way the heads will "scratch" the disk is if the hard drive is jarred beyond its rated tolerance while the disk is spinning.
    2. Disk parking: All new hard disks have a built-in auto-park feature. The head is automatically moved to a "landing zone" or protected area, and held there by a latching mechanism until it is powered up and initialized again. You can hear this happen when you turn off your PC and hear the hard disk make a "click" sound. This happens automatically regardless of a "clean" or "dirty" shutdown. This is why there is an the "I" in IDE (Intelligent Drive Electronics).
    3. Bad sectors: These can only happen in a few situations. One is from a physical head crash (when the disk is physically jarred while operating, causing the head(s) to momentarily come in contact with the disk platter and scratch or pit the surface, causing permanent physical damage). Another way (mentioned earlier) is by a virus program that maliciously marks sectors as bad. Once a sector is marked bad, the OS will no longer attempt to read or write to it. I believe the bad-sector flag will even survive formatting.
    4. If any damage happens from an improper shutdown, it is usually like Aaron said, settings are not saved, or in some cases files are corrupted. The corruption can happen if the file is in the middle of being written when the power was lost (partial update of file) or if some critical area (such as the registry) was not updated properly before power was lost.
    Keep in mind that the OS manufacturers took into account the fact that there are situations when a PC may lose power (such as AC failure, etc.). Thus this is why most OS's (Linux, Windows, etc.) do some sort of housekeeping on the system files and FAT (or whatever type of file allocation system is used) tables when power is restored. Using these utilities as part of a "normal" startup/shutdown sequence was not what the OS companies intended. Improper shutdown is likely to cause problems eventually, so it is always good to do a proper shutdown whenever possible.
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    M²PC Phase IV - *** PENDING ***
  8. #18
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Accord: If you are only reading from a hard drive like traxxis originally said, you cannot corrupt it by cutting power.
    (unless you drop it or something)
  9. #19
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Oh, and I've been cutting power to my hard drive 2 or 3 times a day for almost a year, and don't have a single bad sector! Like I said, you can't corrupt a drive when reading from it!
  10. #20
    Aug 1999
    Yorba Linda, CA
    Post
    Well Accord is right in that the drive is being written even though your software is only "reading". Windows reads and writes to the disk behind the scenes constantly while the OS is running.
    Jason Johnson
    http://www.m2pc.com
