Results 1 to 9 of 9
Thread: slot load dvd question
    Sep 2009
    Hi,
    my question is simple , can i use a slot load dvd in vertical position ?
    May 2006
    Calgary, Alberta
    yes
    If your opening is upwards however, you'll wear out the eject mechanism faster. I've done it.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Sep 2009
    thanks for your answer!
    Jul 2009
    B.C., Canada
    The Wii uses a vertical slot load.
    Apr 2009
    Newark, New Jersey, United States
    Quote Originally Posted by Tical84 View Post
    its more horizontal if u loook @ it the way we are.
    the wii is almost like laying the drive its side. but the ejection mechanism is still pushing out horizontally.
    the OP is probably referring to the disc being ejected UPward.
    Jul 2009
    B.C., Canada
    Oh, ok. My mistake.
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    What about the drives that do not slot load, the "laptop" style trays that POP then you have to actually pull the tray out... Would that wear out faster too>?
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    They might, it's lightweight mechanics working against gravity. At least with the tray load drives, you could push a paperclip in and manually eject the tray.
    Elsewhere
    Quote Originally Posted by we87 View Post
    Load a disc on one of those as you hit a bump and you're buying a new optical drive because the tray is snapped, making it useless.
    How about the Wiki?
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. slot load dvd rom????
    By xtreamvette in forum General Hardware Discussion
    Last Post: 09-30-2004, 07:02 PM
  3. Wtb - Slot Load Dvd / Cd Player
    By SAScooby in forum Classified Archive
    Last Post: 04-25-2004, 08:01 PM
  4. DVD Drive Question (slot loading)
    By breimann in forum Newbie
    Last Post: 03-09-2004, 06:20 AM
  5. Pioneer Slot Load DVD Drive Shock Resistant?
    By Bloomk in forum General Hardware Discussion
    Last Post: 01-15-2000, 05:46 AM
