View Poll Results: Which module would you want the most?
Voters
15. You may not vote on this poll
  • Make an LCD screen module.
    0 0%
  • Make a BLUETOOTH module.
    1 6.67%
  • Make a REMOTE CONTROL module.
    1 6.67%
  • Make a VOLUME KNOB module.
    6 40.00%
  • Make some SENSORS (voltage, current, light, etc.).
    5 33.33%
  • I've got a better idea - check my post below!
    2 13.33%
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Which sensor/module would you want the most?
  1. #11
    Vendor - Qube colin's Avatar
    Dec 2006
    Yeah they aren't for sale yet. If you'd like to pre-order then PM me. I have 13 completed right now but I don't want to send them out the door until I have all 20 in stock.
    As far as the rotary: yes... if it's a mechanical rotary encoder then you can desolder it and use it. There isn't much on the board because it's a very simple circuit. Most of the stuff is done in software (debouncing, calculating the direction, interrupts, etc).
    I've been turning the volume up and down on my laptop all morning trying to get the debounce just right, its been driving the girlfriend INSANE
  2. #12
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    lol nice...
    well, the simplicity of expanding on your qube looks like its mostly software which is what ive been waiting for to automate a bunch of stuff in my truck
    im on board as soon as you decide to start sending them out, so thats one ... maybe two in the future ... 19 more to go
  3. #13
    Dec 2006
    Awesome, they should be out very soon. Waiting on a shipment of more parts!
  4. #14
    Dec 2006
    Today I added support for an RC5 decoder. This means that the firmware has support from the get-go for receiving remote control signals, controlling an LCD, sending/receiving Bluetooth commands, decoding a rotary encoder, and a ton more
    Keep the poll going people.
  5. #15
    Feb 2010
    just checking back to see if you got the rest of your sock assembled and would like to get rid of one...
  6. #16
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Gear position indicator, when not in manual mode (in manual mode, most cars display that in the dash/clock area).
    It's hard to tell with the windows closed without hearing the engine what gear the transmission is on, specially today with cars having 6, 7 and 8 gears. My Sequoia has six, a friend of mine has 8 in his IS-F, and the new FXs have 7 gears. Not easy.
  7. #17
    Dec 2006
    Quote Originally Posted by RipplingHurst View Post
    That seems more like somethin you would pull out of OBD-II...
  8. #18
    Dec 2007
    Danville, CA
    Quote Originally Posted by colin View Post
    No, you can't. I think only Chryslers with extended OBD data can do that. No Toyota, Infiniti or Lexus (and BMW, Mercedes, etc.) can do that. Only via CAN BUS, but I've never seen it done.
  9. #19
    Dec 2006
    Is there some sort of sensor that does it already? If you knew what kind of signals came off the stock sensors, you could certainly interface it...
  10. #20
    Dec 2007
    Danville, CA
    I suppose, I'd have to research. It shows gear in semi-manual mode, I wish it could do the same in full auto mode. But what I meant to say is that it's output (sensor's) is likely to be a digital message to be decoded by the ECU and then sent to the display in the clock). But it may turn digital only after some other intermediate box does some processing (like with the steering wheel inputs, they leave the steering wheel as resistance values, go to a box (media unit or something) then CAN BUS data outputs to the various devices (bluetooth phone, nav, dvd, etc.)
