Results 1 to 10 of 17
Thread: Rev/speed displays....
    Low Bitrate doig's Avatar
    Apr 2003
    Melbourne, Australia
    Hey all
    I had a quick search for this and all i could come up with were some things for the OBD2 system, something that i dont have!
    My idea was simple - take the computer that we have in the boot, and connect it up to the car to monitor (not control, i'm suspicious of anything that can control a car other than my feet and hands) the outputs of the speed, tacho, air temps, etc. The possibilitys of this are endless for people like me that strive to be lazier than i currently am!
    For example - if you usually go for 300 ks before filling up, the computer could easily take care of this for you and tell you when to go and fill up. For drag racing it couldnt be hard at all to get the 0-100s and quarter mile times.
    I'm sure i'm not the only one thats had this idea, has anyone else actually attempted it though?
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    check out AshsZ, he is a member here... but not around a lot.
    here is his website:
    http://ashleypowers.com
    take a look at the Z-car computer system.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Registered User
    Oct 1999
    Blitz Power Meter i-D
    Features:
    The Power Meter i-D can time the following:
    0-200m, 0-400, 0-1km
    0-1/8mile, 0-1/4mile, 0-5/8mile
    0-100km/h, 0-200km/h, 0-300km/h
    0-50mph, 0-100mph, 0-200mph
    $240
    Apr 2003
    I've seen things about the Blitz and apexi rsm's (even put one into a mate's car) but was really after something with more versitilty...
    and the zcar site is good, but it's a little hard to see how he's done it...
    Registered User
    Oct 1999
    Well your going to need a cable that connects your ecu/ecm to your computer then you need software. Thats what Ash's setup is like. try searching the internet,or check bmw modding sites.
    Apr 2003
    Ok i knew that i was going to need a cable to link into the ecu and all that, i guess my question was worded a little vaugly
    Does anyone know how cars transmit the info to the dash? Is the speedo/tach/etc a frequency/voltage or something completely different?
    Apr 2001
    Chicago Suburbs
    alright... i assume that every car built as of the last 10-20 years is going to be entirely controlled by the onboard computer. this means that the guages and other equipment is going to be controlled electronicly. so, the engine data (revs, speed, temp, etc) are going to be monitored by electronic sensors, that are fed into the main computer. from there they are most likely transmitted to the gauges... no more cables from the tranny housing to the gauges...etc.
    big assumption here.. so i hope im right.
    ~Mike
    Aug 2002
    longview washington
    i was giving a schematic of sorts or it was some chip info either way it will let you make a digi speedometer witha few parts like a vss from some junkyard car and stuff i will post it to my web area i am working on if anyone's interested
    oh my bad i just peeked at it its the code to load on the chip and links for the application notes to hook up a lcd and stuff
    oh yeah got another nifty schematic someone else made for a turbo timer / vac/boost gauge and temp and oil and a few other nifty tricks it can do
    WINNER!!!!
    run-on sentance comp 2002!!
    Jan 2003
    I think his question is how does the ecu send data to the gagues in the dash...
    I believe that it is voltage (unless you have a digital gague, in which case I would assume not).
    Apr 2003
    Mike, i dont know about all cars in the last 20 years, but certainly mine does have the electrics into the instrument cluster, no old speedo cables in sight! Thats exactly what i was talking about.
    And they are all normal needle gauges too, so silverjester you think voltage?
    And oddcomp i'd love anything that you've got that i could sink my teeth into as far as this is concerned.....
