Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Windows 7 Hangs on startup with USB hub installed
  1. #11
    Jan 2007
    Quote Originally Posted by soundman98 View Post
    i would get a different hub and chalk it up to experience (even if it was a $60 hub, you are still losing less than me-- i went through 3-$200 audio cards!).
    Soundman...I was hoping you would chime in....I could pick your brain for hours on other Audio related questions...but I'll stay on topic.
    Do you have suggestions on a hub perhaps that has worked better than others? I tried to stick with a name brand (belkin) in hopes of avoiding this...thanks again for trying to help.
  2. #12
    Jan 2008
    powered hubs seem to be hit or miss(or maybe i am thinking of the powered extension cables?). i haven't seen too many bad things about the carnetix powered hub in the mp3car store, but haven't really looked at it too much.
    otherwise, if you have a lot of low power devices, a non powered hub will work just as good.
    i ran a cheap non powered, 4 port hub with my older 945 board--had gps dongle, usb aux port, wifi dongle, and bluetooth on it, and almost everything worked just as good as if it had been plugged directly into the motherboard. i only had issues with the usb aux port, but that was not the hubs fault-- i still have trouble getting those ports to work when plugged directly into the motherboard...
    so i guess a better question is what do you need the hub for?
    for the audio stuff, post your questions when you get a chance or pm me.
  3. #13
    Jan 2007
    Thanks again Soundman. First, the hub is only currently for a couple of items that I need access to while driving (cd/dvd drive which has it's own power, and the charger for my iphone...right now that's all that's connected).
    BUT here is a weird update. Let me first give the disclaimer that I messed with this for several hours over the weekend without getting it to work properly. However today at lunch, I plugged it back in and restarted just for grins, and it worked. I restarted several times and it's restarting without hanging.....so not sure why it's intermittent and what changed, but for now it's working.....weird.
    In regard to the sound questions....I have several that I would like to pick your brain on. I've been in computers for quite some time, and Car audio enthusiest forever....so I never thought there would be so many obstacles to combine the two.....but like I said, I'll keep this thread on topic and PM you or hit you up in one of the other sub-forums.
  4. #14
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    May be completly difernet for you but consider an issue I had a while back.
    When it has worked or not worked has there been any diference with if your phone is pluged in or not?
    I had issues with Win 7 having my iPhone connected via a hub. If I could tell you if the problem was it starting or shutting down with or w/o the phone pluged in I would, but as soon as I figured out it had to do with the phone and the hub I stoped using the hub for the phone and now no more problems. The hub works fine with other devices.
  1. Hardware Review: 4-Port USB Hub CNX-P5USB
    By Sonicxtacy02 in forum The Review Palace
    Last Post: 12-11-2009, 04:02 AM
  2. Windows XP Hangs when Resuming from Hibernation Only When USB Devices Plugged In
    By tbird2340 in forum Software & Software Development
    Last Post: 10-30-2009, 09:37 PM
  3. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 09:50 AM
  4. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 08:16 PM
  5. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 11:38 AM
