Results 1 to 10 of 14
Thread: Windows 7 Hangs on startup with USB hub installed
    Jan 2007
    I just installed a Belkin USB hub. It's powered. I just pulled the power from the 5v leg of my M2Atx. Everything functions properly; however, when I reboot it just hangs at the "starting windows" screen. Initially I didn't realize what the problem was so after several failed reboot attempts I put the windows disk in to initiate a "repair". Well, after it loaded the drivers to go into the repair mode, it hung on "starting windows" and then it hit me that the DVD/CD player was connected to the same USB. I disconnected the hub and restarted and all works again. I can plug it in after startup and everythign works. Any suggestions on a solution? Any help would be greatly appreicated.
    Thanks!
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Is your hub only USB or does it have any other connections (Audio, network, etc)?
    Jan 2007
    Sorry, it's only a USB hub. It has a mini-usb input and a power input and then 4 outputs. Right now I have my DVD player and Iphone charger/interface connected to it. And that's it. Disconnecting any of the peripherals doesn't change anything....only helps if I disconnect the hub itself.
    Jan 2009
    Iowa
    When the hub is plugged in are there any devices not installed/errored in Device Manager?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Try a different hub.
    Jan 2007
    Quote Originally Posted by jpinkerton View Post
    Nope, no error when plugged in. The weird part is it won't startup with the hub connected...but if I reconnect after booted into windows....every device connected works fine.
    Jan 2009
    Iowa
    Like Curiosity said, does a different hub have that same issue?
    Mar 2004
    Florence Yall, BFKY
    You could always disable the BIOS boot from USB/other devices. Sometimes that can hang it.
    Jan 2008
    i would get a different hub and chalk it up to experience (even if it was a $60 hub, you are still losing less than me-- i went through 3-$200 audio cards!).
    Jan 2007
    Quote Originally Posted by Curiosity View Post
    Haven't tried that yet...I'll give that a shot. Thanks for your help.
  1. Hardware Review: 4-Port USB Hub CNX-P5USB
    By Sonicxtacy02 in forum The Review Palace
    Last Post: 12-11-2009, 05:02 AM
  2. Windows XP Hangs when Resuming from Hibernation Only When USB Devices Plugged In
    By tbird2340 in forum Software & Software Development
    Last Post: 10-30-2009, 10:37 PM
  3. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 10:50 AM
  4. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 09:16 PM
  5. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 12:38 PM
