Results 1 to 10 of 12
Thread: Relocate faceplate
    Sep 2009
    Relocate faceplate
    Hi,
    I am halfway through setting up a Thinkpad R52, running Ubuntu, as my car PC. Im working on tweeks to perfect it and im hoping someone can point me in the right direction.
    I would like to have the faceplate to my headunit up above my head (I have a sunglasses holder that will look nice with it) but its not bit enough to hold the whole headunit.
    Does anyone know of 'ready to fit' cabling that will allow me to have the base of the head unit in the centre console and run the faceplace from above my head?
    Jan 2008
    i have never seen a plug-n-play kit for remote faceplate mounting, but it has been done in the past using cat5, and a soldering iron.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by soundman98 View Post
    That's the kit
    1 x roll CAT5
    1 x Soldering Iron
    1 x Solder
    May 2006
    Calgary, Alberta
    I have pictures of a Viper that put the faceplate where the rearview mirror used to be, it was badass. I'll post it if I remember later tonight.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jan 2008
    Quote Originally Posted by Enforcer View Post
    That's the kit
    1 x roll CAT5
    1 x Soldering Iron
    1 x Solder
    you forgot electrical tape/heat shrink
    Feb 2007
    Looks like an alpine 305 or similar,in which case the display part is not removable,only the left part with the controls is removable.That would mean you would have to extend not only the removable faceplate but god knows what the display is wired to most likely a pc board. good luck with that.
    Sep 2009
    Its an Alpine IDA-X200, the face plate does come off.
    I was half way through the Cat5 soldering but its very tricky and the connections are that flexible so will need to take alot of care
    Sep 2009
    Ok, got completing the cat5 cabling today and fitted it in a tempoary position.
    It seems that (click all the buttons then reading the manual) the stereo connection only plays tracks (play, pause and skip buttons control it), it wont constantly play whats attached to it.
    The next plan is to rig the stereo connection straight to the speakers. From what iv read each specker is 4 ohms. Basic ohms law says
    V=IR so I =V/R then P=VR
    12/(4*4) = 0.75A
    Power = 12*(4*4) = 192W
    Can a laptop handle >200W? Is Jack Daniels effecting my mathmatics?
    Thanks for the help
    Jan 2008
    your talking about connecting the laptop to directly to the speakers right?
    if so, the voltage output is very small, and will barely power a small speaker, lot to mention a car audio speaker.
    you will need a amp of some sort to boost the signal--either a factory amp, small motorcycle amp, or aftermarket car audio amp.
  1. Replies: 13
    Last Post: 06-22-2009, 09:23 AM
  2. Has anyone made a custom stereo faceplate?
    By zOMG in forum Fabrication
    Last Post: 01-03-2008, 06:42 PM
  3. Remote faceplate! turned out really nice, check it out
    By Sporttracguy in forum Car Audio
    Last Post: 02-23-2007, 02:07 AM
  4. Relocating faceplate on an alpine deck
    By BavarianBuilt in forum General Hardware Discussion
    Last Post: 10-29-2006, 11:48 PM
  5. pioneer headunit faceplate question
    By carabuser in forum Car Audio
    Last Post: 04-06-2005, 06:10 AM
