Results 1 to 5 of 5
Thread: Fifty dollar sheevaplug
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Well, it's not quite a sheevaplug, but it's close. It's actually a pogoplug, and it's fifty bucks:
    Seagate DockStar
    It only has 128M ram instead of 512, but other than that it's no less functional than a regular sheevaplug. It's trivial to start messing with:
    OpenPogo Installing Base Package [USB]
    The other benefits of this for this forum are four built in USB ports [counting the "dock" type mini usb port], and the power is 12V. You'll still need a regulator, of course, but you won't have to crack the thing open just to replace the PSU.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Mar 2009
    Los Angeles
    OK, so after much futzing, I've found at least one major major issue with the device; it lacks a hardware clock. When it powers up, it thinks it's the unix epoch every time.
    Of course, that's fine for seagate since it's meant to be connected to the internet all the time and it runs ntp. Not so fine for an unconnected car :-/
    Gary (-;
    Sep 2010
    GPS synchronization
    Quote Originally Posted by chunkyks View Post
    Gary (-;
    Have you considered using the GPS to synchronize Dockstar's clock upon startup?
    I've googled a bit and found this: http://www.punknix.com/node/116
    Hope it helps!
    Regards,
    Antonio
    PS: I've been going through your work on OBD2 and I really appreciated it ;-) Nice work. I'll probably get my own install soon.
    Mar 2009
    Los Angeles
    Yes, I did actually. The problem with that is that the time servers that do it [chrony's the best for talking to gpsd, after much experimenting] all take a long time to sync to the point they're willing to change the time.
    In the end, I actually added "gpstime" to the gps table and a tripid to the obd and gps tables. That way the schema's safe to use in the face of erroneous localtime responses, and the "actual" time is available in the gps table. Since I was touching the schema, I took the opportunity to add speed and heading, as reported by gps, to the gps table too.
    And then I fried my dockstar, so now I'm trying to decide between buying a beagleboard xm, an igepv2, a guruplug server plus, or something else.
    Gary (-;
    Sep 2010
    oh...... too bad it takes too long...
    About you Dockstar, may I ask how did you fry it? I was planning buying one and connecting it through a 12V regulator directly using a LM7812 1A just in case it can't handle the car's 13.8V.
    I was quite interested in the Guruplug but I've seen too many people complaining about overheating. Moreover, the newest revision, which "solves" this has a very noisy fan inside Check http://www.globalscaletechnologies.com/news.aspx and http://plugcomputer.org/plugforum/in...p?topic=1735.0
    Regards.
  1. Replies: 1
    Last Post: 03-31-2010, 12:39 PM
  2. SheevaPlug butchering
    By chunkyks in forum Power Supplies
    Last Post: 01-28-2010, 01:05 AM
  3. SheevaPlug Wishlist
    By chunkyks in forum Linux
    Last Post: 01-12-2010, 01:17 PM
  4. We need to source the 100 dollar laptop parts.
    By Snortonnorton in forum Wireless Communications
    Last Post: 10-03-2007, 12:32 AM
  5. WTB Allbrite 10.4" will pay top dollar
    By rexus in forum Classified Archive
    Last Post: 07-30-2003, 03:38 PM
