Results 11 to 20 of 22
Thread: MIniITX without Atom CPU?
  1. #11
    Feb 2010
    Temple, TX
    Quote Originally Posted by Nomader View Post
    are there any NEW MiniItx motherboards around that do not have built in Atom Cpus with Normal PCI (not express)
    I want something more powerfull..like a normal CPU.. i have a DSATX and i don't care about power much.
    I just ordered a
    ZOTAC GF9300-I-E LGA 775 NVIDIA GeForce 9300 HDMI Mini ITX Intel Motherboard
    from newegg.com. It is supposed to come in Friday. I ordered it because it is one of the newer boards (DEC09) that supports a 755 socket. I had a older core2duo 2.6ghz laying around and some DDR2 ram. It seemed like the best and cheapest option.
    *********Just reread the post and see that you are looking for reg PCI slot sorry****************
  2. #12
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by tripzero View Post
    mo-co-so.com has a case with a pci-slot
    you r right!!!!!i like that case!!!!
    http://www.mo-co-so.com/ProductDetai...Show=TechSpecs
  3. #13
    Apr 2006
    Greece
    Quote Originally Posted by Madboy View Post
    My Car-PC is under the seat
    So I actually use a Mini-ITX cube case : CFI-A8989
    http://www.chyangfun.com/pro04_1_1.asp
    If you have the room for it , I really recommend it
    i have a similar cube case + a micro ATX board, in the trunk, i was just looking for something smaller..no way i can squeeze this under the seat
  4. #14
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    I wouldn't limit myself with the PCI slot...there are a lot of adapters that you can use if the board has different PCI connections aside from the old 'normal' standard.
  5. #15
    Apr 2006
    Greece
    Quote Originally Posted by S4Per View Post
    what do u mean? i haven't found a pci express-pci dapter anywhere..
  6. #16
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    I reread, but I didn't find the reason why you need the PCI slot. Maybe I missed it? The card that is to go in the PCI slot, can you get a PCI-Exress or USB version of it? What is it?
  7. #17
    Apr 2006
    Greece
    Quote Originally Posted by jpinkerton View Post
    nope...it is an old radio-tv card..(Cinergy 600) which works very nice...and i love very much
  8. #18
    Jan 2009
    Iowa
    Gotcha! I'm sure you could find a new similar one in a PCI-Express version, but I understand when you have something like that, that you love.
  9. #19
    Jan 2004
    Seattle, WA
    here's one for starters: http://www.startech.com/item/PEX1PCI...pter-Card.aspx
  10. #20
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    there are some nice VIA Nano (not nano-itx, Nano CPU) mainboards out there. The nano is currently a single core but it does pack quite a punch and is very comparable to the Atom.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. should i replace motherboard or cpu??
    By trinybwoy in forum General Hardware Discussion
    Last Post: 03-06-2010, 08:44 PM
  3. Dual-core 330 Atom CPU - win XP, 7 or server ?
    By sergatiuk in forum WinNT Based
    Last Post: 10-20-2009, 09:24 PM
  4. Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By lucegunz in forum General Hardware Discussion
    Last Post: 06-17-2009, 11:06 PM
  5. Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By PORTUGAL in forum General Hardware Discussion
    Last Post: 05-18-2009, 11:05 AM
