Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: MIniITX without Atom CPU?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    are there any NEW MiniItx motherboards around that do not have built in Atom Cpus with Normal PCI (not express)
    I want something more powerfull..like a normal CPU.. i have a DSATX and i don't care about power much.
    Oct 2004
    Israel
    I use Intel DG41MJ
    I think it is the only Mini-ITX board with a 775 Socket and PCI slot
    I works OK
    I have some issues with the usb slots ( seems like it lacks a little bit power ) which I kinda manage to handle with a powered hub
    But other than that it works really well
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Apr 2006
    Greece
    what CPU r you using..and what power supply?
    Oct 2004
    Israel
    E7500 On M4-ATX
    Apr 2006
    Greece
    Quote Originally Posted by Madboy View Post
    E7500 On M4-ATX
    r u sure it is the only one? unfortunately it has no HDMI and no serial port
    Dec 2005
    Raleigh, NC
    There are two AMD boards that I found right away with your requirement of MiniITX and PCI slot:
    JetWay JNC84-LF
    JetWay JNC81-LF
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
    Oct 2004
    Israel
    Quote Originally Posted by Nomader View Post
    You got a serial port inside ( pinout )
    And why do you need HDMI? you got a DVI on it..
    And yeah I was only talking about Intel CPU's ( Not a fan for AMD - for no reason actually )
    Apr 2006
    Greece
    you r probably right..
    are there any cases that support the PCI? or does everyboy use a riser and having the pci card hidden?
    Oct 2004
    Israel
    My Car-PC is under the seat
    So I actually use a Mini-ITX cube case : CFI-A8989
    http://www.chyangfun.com/pro04_1_1.asp
    If you have the room for it , I really recommend it
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    mo-co-so.com has a case with a pci-slot
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. should i replace motherboard or cpu??
    By trinybwoy in forum General Hardware Discussion
    Last Post: 03-06-2010, 07:44 PM
  3. Dual-core 330 Atom CPU - win XP, 7 or server ?
    By sergatiuk in forum WinNT Based
    Last Post: 10-20-2009, 08:24 PM
  4. Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By lucegunz in forum General Hardware Discussion
    Last Post: 06-17-2009, 10:06 PM
  5. Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By PORTUGAL in forum General Hardware Discussion
    Last Post: 05-18-2009, 10:05 AM
