Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: cables to front of car?
  1. #11
    Mar 2001
    DDO
    Post
    Ok.. Sorry I misunderstood the post!
    There are signal repeaters/amplifiers but they're not exactly cost effective
  2. #12
    May 2000
    Ft Gordon, GA
    Post
    smashr2k: if you can find me a shelby for sub $4000.00 then please let me know.
    caviar: can you please post the link.
    i will try anything at this point. ive put too much time and money into this for it not to work in my new car. thx for all the info everyone!
    etrik
    "if everything is under control, you're not going fast enough!"
  3. #13
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Cool
    I read about someone using Octal Drivers to amplify IDE signals. It didn't matter what type of cable you used (IDE, CAT5). I don't remember the example page, but I have a link to the driver schematic and a good place to pick these things up. Each one amplifies 8 wires, so you'd need 5 for an IDE cable. They cost about 50cents apiece, so no big deal.
    http://www.fairchildsemi.com/ds/DM/DM74LS244.pdf
    http://www.web-tro nics.com/webtronics/ls244.html
    External USB IDE case (pricey...)
    http://www.startech.com/parts/HARDDRIVE.htm
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  4. #14
    Mar 2001
    DDO
    Post
    The usb is unfortunately useless due to its speed limitations (for DVD that is).
    You coud check out a firewire (ieee-1394) drive. I know the G4 has an internal firewire port but I dont know if anyone produces an internal firwire DVD drive....
    On the other hand if I remember correctly 1394 boards are EXPENSIVE
  5. #15
    Jan 2001
    Mississauga - Ontario - Canuckland
    Post
    how freaking stupid of me.........here is the link, sorry
    http://www.winwood.net/~oacar/faq/
    there is not much on that page though ... doesnt explain in detail.
  6. #16
    May 2000
    Ft Gordon, GA
    Question
    ok. so with the amplifyer chip there is an input and an output for each wire. that i get. buth there is also 2 enable pins (1g and 2g) a vcc pin, and a ground. what do i hook these up to. sory for the ignorance but im new to breadboarding.....
    etrik
  7. #17
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    The "long IDE cable" topic has been covered 15 times this month. Use the search feature to locate the answers.
    The VGA should be fine at that length. I've run it 150 feet with a good shielded extension cable.
  8. #18
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    Post
    etrik :
    If I found a Shelby for less than $4000, then i most definatly would not tell anyone else about it untill it was safe in my garage.
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
  9. #19
    May 2000
    Ft Gordon, GA
    Question
    has anyone used these buffer chips that pato mentioned? like i asked earlier:
    aaron: i did search! moon deleted the archive whe he updated the board apparently.
  10. #20
    Constant Bitrate monger's Avatar
    Nov 1999
    Good ole Maine. Gotta love trees and deer.
    Post
    Has anyone thought about SCSI? Length requirements are measured in meters, not inches. Furthermore, how hard can it be to find a SCSI DVD drive? This easy. Here is a link to one that is not that expensive, and requires no cable modification. Just run a ribbon cable to the dash and go.
    Thought I would throw another option into the sea of ideas floating around in here.
    Monger
    ICQ-7207702
    UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
