Results 1 to 10 of 20
Thread: cables to front of car?
    May 2000
    Ft Gordon, GA
    Question cables to front of car?
    ok, i have my setup working well installed in the center council of my car but now i was offered a new car that i really want ('61 checker superba ) for a really good price. my problem is how do i run all the cable from the trunk to the front. i now i can just get an extension for the mouse and serial (irman, gps) but what about the parallel (lcd), the vga (tft), the ide (dvd), and the power to run it (right now i tap into my dc-dc atx psu)? any help would be greatly appreciated.
    etrik
    "if everything is under control, you're not going fast enough!"
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Heh, I've never even heard of this car before, so I went and googled.
    Heh. An old car with a modern computer in it
    As to moving it to the trunk, just extend the wires. You can buy extension wires for everything you listed.
    http://mp3box.2y.net/installation.html
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Oh, except the ide DVD is debatable. You might want to install that near the trunk and use a normal cable. There's a thread about that, so search for it.
    May 2000
    Ft Gordon, GA
    Post
    yep thats the car . except the one im getting is a really light pink (almost white). thx for the info.
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    Post
    ummm... in MOST cars, there is a sorta "wiring conduit" on both sides under the doors. there is a small panel you should be able to remove.. now on that old of a car, i dont know. you should definitly give in and buy a 1967 Shelby Mustang GT500 Fastback
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Jan 2001
    Mississauga - Ontario - Canuckland
    Post
    yo etrik,
    go to this page and then click on DVD.
    its says to use cat5 to extend the IDE wire to the front.
    Mar 2001
    DDO
    Post
    Caviar.... err..
    There's no link...
    Aug 2000
    Oregon
    Post
    I'm REALLY not sure that even cat5ing an IDE cable makes it okay to run it that far. I understand twisted pair could improve the signal degridation over the length, but that's an awful long trip for IDE data. It might work, but I'd be really afraid of data loss.
    If this does work for anyone, even partially... setting the drive type to the lowest PIO mode possible (and NO DMA) in the BIOS might make the distance more forgivable? I think the little IDE cables we have now might be pushing it with these new DMA/100 speeds.
    Using SCSI is just too expensive, it offends my sense of value in this project. USB would be PERFECT, but it's TOOOOO SLOOOOOW.
    Anyone know anything about firewire? Distance? IDE->Firewire converters? humph.
    -M
    Mar 2001
    DDO
    Post
    Actually seeing as CAT5 is rated for speeds in excess of 1000mbs (re: gigabit over copper) it should work just fine!
    I have a friends whose tried it with a cd-rom and he told me it works beautifully over 10'. But I would like to see more setups before I attempt it
    Nov 2000
    Chapel Hill, NC, United States
    Post
    I don't think that the CAT-5 would be the problem, it would be the strength of the signal sent. Sure CAT-5 can handle a gigabit, but that is probably a much stronger signal so it isnt affected as much by interference. If there was a way to increase the strength of the signal at one end and decrease it at the other, that might work.
    Got started with computers on this board early in high school...now I run a web development company and am about to build my dream machine.
