Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Zotac NM10-ITX
    May 2008
    Bend, OR
    Zotac NM10-ITX
    So I'm now on my second board.
    It's all built and populated with the Broadcom Crystal Vision HD mini-pcie, U-Blox mini-pcie gps and, mini-pcie wireless card (factory)
    Only problem is it won't boot with the M3-ATX power supply! Only from a desktop supply. It will reboot if you hot-add the cards but not boot. Damdest thing. I wonder if my M3 is bad, but it boots my other rig, and works fine on reboot.
    I finally thought I had the most complete rig and now this grrr.
    Apr 2010
    Sounds like your new rig is drawing more juice than your M3 can deliver, try pulling those pcie cards, and the HD and see if you can post then.
    Elsewhere
    jdwk is 100% correct. More power draw than the M3 can handle.
    How about the Wiki?
    May 2008
    Bend, OR
    See I thought that too, but it handles it fine it is just rebooted. Also the only power additions are the broadcom decoder card and gps chip. The max a mini pci device can draw is 1A, so 2A does not near put me over budget. Also if the device is moved from one slot where it boots fine to the other it stops booting. So I'm confused.
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Wait, why are you unplugging things from the motherboard while it's running? Are you going to do that while you're trying to drive to get your CarPC up and running?
    Are you sure you added up EVERYTHING? INCLUDING the motherboard? The processor? All the devices plugged into the motherboard? Anything else running off the M3?
    Everything works fine with a different setup, is that setup LESS power than the Zotac setup?
    I'm with DP and jdwk - you're drawing too much power (even if it's only at boot) to use that setup. You're going to need to beef up your PSU.
    Elsewhere
    One thing to remember:
    When you're powering on from cold, there are some devices (HDD & optical drives, I know for sure) that draw more power at startup, as they have to spin up and such.
    They wouldn't need that extra burst of power when doing a warm reboot.
    How about the Wiki?
    May 2008
    Bend, OR
    Yep thought of that too, I have zero optical devices and HD's connected.
    I also thought the same about power load, So I just swapped the WiFi for GPS (which draws less) and same problem.
    Also when the systems's live I plugged gps into the one slot system finds it fine. I try the other slot it's not recognized.
    (btw Mini-pcie == USB so you can hot plug it.)
    Jan 2009
    Iowa
    Quote Originally Posted by steven765 View Post
    btw Mini-pcie
    Okay, that sounds better! I must've misread in the beginning because I thought you were pulling some card in and out and I'm on the other end wondering how everything is still happy!
    I still think it's a power requirement issue. I know it's an Atom setup, but it just seems like not enough to give it that initial boot.
    May 2008
    Bend, OR
    Just had a fascinating conversation with zotac tech support:
    Me: Any idea why moving the gps card from one slot to the other and the system won't recognize it.
    Support: There's only one slot.
    Me: No there's two, here's a link to the pic of your product. (two mini-pcie slots clearly visible)
    Support: Right only one slot.
    Me: Umm you realize the wireless module is removable right?
    Support: Yes that's the only slot.
    Me:
    Support: I can see this is going to be an education for me.
    After 30 minutes I end up having to e-mail tech support. This makes me wonder who's answering the live chat tech support. And after sending him copies of the spec sheet showing two mini-pcie cards he thanked me for helping. Anyway he's going to track down the power requirements for each rail 3.3, 5, and 12.
    In my professional assessment I believe they have issues, because just moving a single card from a working slot to another makes it not work. This eliminates power as the culprit and makes me think they FUBARED the wiring on the extra slots... or the BIOS.. or the power supply.... or....
    Wow
    Jan 2010
    Re:
    Isn't the Zotec system a 19V system and isn't the mt3 only verified at 12v? wouldn't it be better to try the cnx p2140 which i'm pretty sure can handle 20v out? Just questions, interested to see how this goes for ya.
  1. ITX Build Info/Help Needed
    By Haydon92 in forum Newbie
    Last Post: 03-10-2010, 10:59 AM
  2. ZOTAC GeForce 9300-ITX WiFi GF9300-I-E
    By RipplingHurst in forum General Hardware Discussion
    Last Post: 02-18-2010, 02:56 PM
  3. ZOTAC MAG -- How will it work for a carpc?
    By xiledsavior in forum Newbie
    Last Post: 01-13-2010, 06:44 PM
  4. Zotac 9300 ITX board bends with CPU cooler
    By bmw_car_pc in forum General Hardware Discussion
    Last Post: 05-19-2009, 02:58 PM
  5. Zotac Mini ITX Board
    By buckaneer in forum Power Supplies
    Last Post: 12-10-2008, 09:10 PM
