Can you post some pictures?
I took the backplate off my G4 car pc and unfortunately managed to pull one of the wires from the cooling fan off the little plastic connector plug.
I tried to open up the plug to see if I could reattach the wire but it looks like it is factory sealed. I managed to lever it open but it broke into several pieces. I guess that they are a throw away item.
I have been looking on ebay etc for a replacement fan (50x50x10 12v DC) and found plenty. However the plug on all of them appears to be larger than the one that was on mine. It is tiny (about 4mmx2mm 3 pin female).
Has anyone come across this type of connection plug?
I did find this fan for $3.25 + shipping. It has what appears to be a similar plug, but I'm not positive on that.
I also found this adapter that will convert the normal 3pin fan connector to the mini 3pin fan. This adapter would give you some more flexibility when choosing a fan, and you wouldn't have to disconnect the fan in the future from the connectin inside - giving you more reliability down the road too.
Hope this helps!
I could use the original fan as it still works ok. But I couldnt find a suitable replacement plug.
I looked on Farnell etc but there are thousands of connectors. I could probably find it if I knew what to look for. Usually this type of connector has a generic name (like TX3?).
the adpator looks like to will do the job, just buy a standard fan and use that adaptor
This adapter is what you need then. It's a large male part (that's what she said) and a small female part.
To make your existing fan work you could take the normal (large) connector off a spare fan, splice it onto the existing fan and then use the adapter.
The pitch is 1mm not 2 so that adaptor wouldnt work.
One of the guys from a uk forum suggested one of these. It looks very similar to the old one.
http://uk.farnell.com/multicomp/mc34...way/dp/1578139
