Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Computer instability...Hardware problem?
  1. #11
    Apr 2010
    pandora bracelet
    they way you worded it there it sounds like you may have the M2-ATX set to "standard atx function" or may not have the ignition wire (the white wire) properly wired. This could cause the system to power down improperly and in turn give you the windows errors you're seeing.
  2. #12
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    O.o
  3. #13
    Oct 2006
    also check your device manager to see if there is any device with "?" or not installed drivers.
    I had this issue with my bluesoleil driver that cause my computer to restart with the "windows has recovered from an error" at startup.
    I also have occasional bsod that appears to be xport's issue which curiosity is currently working on.
  4. #14
    Jan 2007
    Quote Originally Posted by Punky View Post
    Thanks Punky....I did so and this is what I found....
    I'm hoping some of you guys much smarter than me can shed some light on. I have been looking for issues items that could be the cause of all these problems. In device manager, nothing showed a problem; however, I noticed under "view" in device manager, there is an option to show all hidden items as well. I did this, and a system file was "stopped" and it said the device could not be started properly. It was "null.sys" in the windows 32 folder. I couldn't "manually" start this, so I clicked "uninstall". Now, it shows no error, but what is null.sys? I did a search and many say it is a cause for BSOD and crashing (which I was experiencing)...but was mine corrupt and I need it? Haven't had a startup issue since I removed it; however, boot times and resume is really slow (like 2 minutes or more).....suggestions?
  5. #15
    Feb 2006
    Melbourne, Australia
    Your system is not being shut down proper. Check PSU setup.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  6. #16
    Jan 2007
    Quote Originally Posted by mrbean_phillip View Post
    What should I check for Mr. Bean? I have an M2ATX which is set to sleep after 5 seconds and hard off after 2 hours....after I disabled the null.sys....all this functions properly. However, over on the CF forums...MarcelP said I needed this service to be running, so I restored back to it and now system is crashing again; however, still says there is a problem in device manager. It gives the error that it can't find the file in system32/drivers....though when I physically check....it is there.
  7. #17
    Feb 2006
    Could you replace that file then? Certainly seems there is something with timing on shutdown that is causing problems with W7......
    I have a M2- ATX which I could try on one of my Zotac boards, and see if I have the same concern - with the Carnetix and PicoPSU combo, no problem though.....
  8. #18
    Jan 2007
    Weird!! Ok, I completely formatted my computer. On fresh start, Null shows fine in device manager. Windows prompts me for a mandatory update, and immediately after restart, the exclamation point shows up over the "null" in device manager. What the heck? Any suggestions?
  9. #19
    Jan 2008
    maybe you could try rolling back your computer to right after the fresh install, and determining what the update was?
    if you do determine that it is the update causing the issue, don't use that update..
  10. #20
    Oct 2006
    most likely you have a device that is missing driver for windows 7, you'll have to identify which one it is and locate the driver for it. Or when you figured it out and have no driver, you can always disabled it in bios or remove it from hardware if it is removable
  1. Wi-Fi Networking problem
    By GreenHorn in forum Wireless Communications
    Last Post: 10-25-2009, 04:48 PM
  2. "verifying dmi pool data"
    By dougbrooks in forum Newbie
    Last Post: 08-15-2006, 11:09 PM
  3. Problem building a new computer... can you help diagnose?
    By azzurro in forum General Hardware Discussion
    Last Post: 12-23-2005, 09:58 AM
  4. Computer Building Problem
    By 0l33l in forum General Hardware Discussion
    Last Post: 05-09-2005, 02:52 AM
  5. not so much a hardware....but XP problem
    By b15ginz in forum General Hardware Discussion
    Last Post: 03-31-2005, 06:01 PM
