Go into Control Panel. I am presuming you are using
Windows as your OS.
Select System, then Device Manager. Find "Universal Serial Bus controllers" and click on the plus to open it.
You are looking for "USB Root Hub", you will have as many as you have hubs. Click on the first one, the click the
Power tab. It will tell you whether the hub is self powered or powered. And the Total amount of power available: 500 mA per port. So a four port hub "should" be able to sink 2000 mA, or 2A. Thats 2A times the number of four port hubs available.
You will also see what devices are attached and their Power Requirements. Say a
Bluetooth adapter around 50 mA. Another hub connected to it 400 mA. USB hard drive 500 mA.
My guess is that the ones drawing 500 mA can probably draw a lot more. I have a hauppauge USB TV stick. It's documentation suggests that it be on a hub by itself if the hub is unpowered. Experience shows me it can coexist on a powered hub with a Bluetooth adapter.
I also have a Seagate FreeAgent USB drive that derives all of it's power from the hub and can be the only thing living on it powered or otherwise.
What is happening is that certain devices will draw more current than their ratings show, hard drives in particular. And will monopolize the entire hub.
You will have to try different combinations to see what is actually stable. You may also want to power all of the hubs through a voltage regulator.
Good Luck
