Results 1 to 5 of 5
Thread: intel d945gclf2 & M2atx strange issue
    Oct 2009
    Hi everybody,
    I'm new here and almost a newbie in carputer.
    I explain my problem:
    I have an intel d945gclf2 mainboard and a M2ATX powered by a normal ATX power supply; now the problem is that when I turn off the pc (regularly), then I couldn't restart it till I phisically disconnect M2atx from the power supply.
    This didn't happen with my old via m10000 mainboard, so I have to think that exist an incompatibility between d945gclf2 and m2atx.
    Moreover it lose date and hour setting every reboot.
    It's over a month I've searched for a solution, but i couldn't find any.
    Does anyone find a solution?
    Please help me, this situation is driving me mad!
    Thanks all in advance,
    and sorry for my bad english
    Jan 2008
    how are you turning off the pc? are you turning off the atx power supply, or are you choosing 'shut down' in the computer?
    also, what jumper settings on the m2 are you using?
    Oct 2009
    I turn off the pc choosing 'shut down' (or hibernate, it behaves in the same way); I tried also with the shutdown button linked to the mainboard, but obviously doesn't change anything.
    I've tried many setting of M2 jumpers, but also in this case doesn't change anything. Anyway, for "normal use", I use "A" setting for jumpers (it should stand for 5 sec/ 45sec if I remember correctly).
    Thank you for your help!
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    there was a recent issue of the same sort where i think some one else went through two boards with the same problem.
    some body else pointed out to check the cmos battery and update the bios, but i dont think any of that worked for them and they gave up on the d945gclf
    i myself had that issue when i had a memory card in a usb port, regardless of any bois settings it would just not post with my memory card in it, i updated the bios and problem solved... most of the time. as far as the resetting of the clock date/time i had that when xp was not shut down properly, xp hung up while shutting down, diver issue, and/or m2 was cutting power before xp could finish hibernating, or the board lost power while in s3...
    Oct 2009
    I have some more informations:
    - if I let M2ATX choose to start/stop the system, it works fine;
    - if I choose to start/stop the system both with button and with windows' start menu, it won't reboot; in this case the only way to reboot the system is to unplug the ignition wire for a time depending on what setting I choose on M2atx (A, B, C or D).
    After doing that, appears ALWAYS a message concerning time and date lost in cmos settings.
    Any idea?
    thank for your help
  1. Strange M2 issue.
    By tag141 in forum M2-ATX
    Last Post: 02-17-2010, 12:54 AM
  2. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 03:39 PM
  3. Audio issue with Intel Mini
    By iamgnat in forum MacCar
    Last Post: 06-27-2006, 07:01 PM
  4. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 01:16 PM
