Results 1 to 5 of 5
Thread: Case power jacks
    Feb 2004
    Case power jacks
    I have a mini-itx case that I'm dropping a DSATX into. I'm looking for a clean way to connect power, ground, ignition, and remote lines to the power supply, which is not exposed outside of the case. I will probably end up powering my touch screen and a USB hub from the power supply as well. I would like to have the ability to quickly disconnect everything.
    I was thinking about just adding a series of panel mount coaxial jacks that accept barrel plugs, but it looks like finding a jack that can handle the current requirements of the DSATX may be a problem. The last thing I was considering was just to bore a hole, slip in a vinyl grommet, and simply leave several inches of exposed wire with insulated spade connectors dangling. It's definitely more ghetto, but functional.
    Any suggestions?
    Apr 2009
    Newark, New Jersey, United States
    you can use moxlex connectors...
    Uploaded with ImageShack.us
    Apr 2009
    the molex on the left is used to power my LCD screen and 7-port usb hub.
    the molex on the right is used to power the dsatx
    Jan 2008
    otherwise, look for anderson power poles--they are a high current connector that can be linked together, and have many colors for easy identification:
    http://www.alliedelec.com/Search/Sea...FQseDQodMTsX2Q
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jul 2001
    May want to look here, this is what I use...
    http://www.conxall.com/Catalogs/catmenu.htm
  1. Power supply / case query...
    By skinhead in forum Power Supplies
    Last Post: 11-19-2007, 05:41 PM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  3. Replies: 4
    Last Post: 03-21-2006, 07:00 AM
  4. Hmmm, 3677 case + power brick
    By NJay in forum Power Supplies
    Last Post: 02-02-2004, 02:05 PM
