Results 1 to 3 of 3
Thread: Internal Wireless Antennas
    Feb 2004
    I'm going to pick up a mini pci-e wireless card, and many of the newer chipsets are now using 3 antennas. I don't want to have three antennas outside of my case, so I'm considering just getting three internal antennas. Anyone know how much of a difference external antennas make? My laptop has good range and easily matches the range of my other carputer that has a pair of external antennas, so I can't imagine they make that external antennas make that much of a difference.
    Elsewhere
    An internal antenna will not be as effective, since the radio waves will have to go through a physical barrier.
    Depending on the barriers and what they are made of, it could make a big difference.
    If the barrier is a thin piece of plastic (like a laptop shell, for example), it won't be a big deal.
    If the barrier is a sturdy steel or aluminum case, it will make a big difference.
    How about the Wiki?
    Jan 2008
    i guess it depends on how strong the wireless connections are that you are planning to connect to.
    my car would barely get 13mb/s with my old single ant. usb dongle in the dash, but changing over to a dual 3db gain ant. usb card mounted in the top of the windshield now gets me 54mb/s at home.(i have a convertible, so the rear window would not have worked..)
    if you plan to ever borrow wireless from any of the local businesses that offer free wifi, i would recommend trying to get the best wireless reception as possible-- otherwise, you might not be able to get a strong enough signal..
  1. Internal PCI-e wireless card, two leads?
    By RedGTiVR6 in forum Wireless Communications
    Last Post: 07-29-2008, 01:26 PM
  2. internal antenna's for FM or TV
    By GLO in forum General Hardware Discussion
    Last Post: 04-03-2008, 05:54 AM
  3. what kind of outdoor wireless antennas is everyone using?
    By shrinkydinx in forum Wireless Communications
    Last Post: 03-10-2006, 03:16 PM
  4. wireless card or wireless car and access point?
    By vanroth in forum Wireless Communications
    Last Post: 06-08-2004, 11:46 AM
  5. Extending wireless device antennas
    By schrodos in forum General Hardware Discussion
    Last Post: 06-14-2001, 12:14 AM
