Results 1 to 7 of 7
Thread: M4-ATX Case
    Newbie SorentoUltimate's Avatar
    Dec 2009
    Moschato, Athens, Greece
    Lightbulb M4-ATX Case
    Hello,
    I try to find a Case for My CarPC Project Compatible with M4-ATX Power Supply.
    Can anyone give me links with cases i can use with M4-ATX Power Supply ?
    Thanks In Advance
    SorentoUltimate
    Newbie IronDuke84CS's Avatar
    Nov 2007
    Ohio
    Lightbulb Re: M4-ATX Case
    The M4-ATX doesn't fit in most CarPC cases. I haven't seen anything specifically for CarPC use, but maybe this can be modified for your use.
    http://www.mini-box.com/M4-ATX-SFX-ATX-enclosure
    This seems like a nice solution too.
    http://www.mp3car.com/vbulletin/powe...enclosure.html
    Good luck!
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Depends on what kind of case you're looking to use. Check my Honda project link for pictures/information on the larger scale case I'm using with an enclosure just for the M4.
    Dec 2009
    Thanks a lot for your answers,
    i try to find a case to put M4-ATX, Motherboard etc.
    but after a lot of search nothing....
    i have in my mind somethning like Black Box PCI Mini ITX Case for Carputer Car PC with PCI Slot http://www.mo-co-so.com/Black-Box-PC...cs-bbm-pci.htm
    Another possibility is to take the above case and work on it to put M4-ATX Inside
    What do you think?
    Nov 2007
    Ohio
    I use an M4-ATX with a Little Falls 2 mobo and I couldn't find anything that didnt need modification either. If you're handy with a Dremel, you can make what you need like I did. Granted, it doesn't look like an amplifier, but it works great! Oh, and since this pic I added another 2.5 HDD, still runs cool. I started with a standard card file box and made templates for all the devices I wanted in it and started planning with wiring and airflow in mind. I'll post pics again after I paint it.
    http://i715.photobucket.com/albums/w...012010_012.jpg
    Dec 2009
    Exclamation
    thanks for idea !!!!
    Nov 2007
    Ohio
    You're welcome.
    BTW, I got that card file box at the Goodwill store for $1.50
  1. 24 pin m4 atx to 8 pin mother board
    By withoutcomp1 in forum M4-ATX
    Last Post: 06-03-2010, 08:47 AM
  2. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 07:43 AM
  3. Any micro atx case smaller than this?
    By phatmonky in forum General Hardware Discussion
    Last Post: 03-30-2008, 01:24 PM
  4. Help me find the smallest Mini ATX Case
    By snoopdan in forum General Hardware Discussion
    Last Post: 05-11-2006, 02:38 PM
  5. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 06:04 PM
