Results 1 to 10 of 11
Thread: PSU: How am I supposed to connect?
    Low Bitrate capcadetjc's Avatar
    May 2008
    Lubbock, TX
    I have a GP83 160W Intelligent DC-DC PSU and the D945GSEJT Fanless, UltraFlat mini-ITX motherboard. It has NO ATX power connector on it. It only has the 12v and P4 connectors. I cannot find anything on how to connect a DC-DC power connector to it. Can anyone shed some light on this for me?
    My 2007 Jeep Wrangler Worklog
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Sorry to say, but it looks like your DC-DC PSU is not needed.
    Your mainboard is ment to be run by an external power source (the 12V).
    May 2008
    Lubbock, TX
    Is there a way I can wire one of the 12v pins or whatever they are called to the ATX connector on the PSU?
    May 2008
    Lubbock, TX
    What if I ran a power and a a ground from the ATX connector on the PSU wired them to a socket for a cigarette lighter, then plugged in a dc-ac converter to that, then plugged in the powersupply for the computer to that. So I would have DC to (DC to AC) then back to DC. I know its not energy efficient but it sounds like thats the only way I can use the power supply to be able to use the wait so long before turning off feature.
    Nov 2006
    Rubidoux, CA
    If you want to use that PSU, you SHOULD be able to use the 12V lines on the PSU's ATX connector to feed the 12V to the motherboard. Would then take jumpering the enable lines on the ATX to get it to turn the power supply on.
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
    Elsewhere
    This is one of many situations that can be avoided by proper planning.
    I'm just sayin'.
    How about the Wiki?
    May 2008
    Lubbock, TX
    And proper item descriptions. They shouldnt put compatible with all Mini-ITX mother boards on products that arent.
    Nov 2006
    Rubidoux, CA
    Quote Originally Posted by capcadetjc View Post
    The problem is, the Mini-ITX standard calls for the ATX power supply connection as well. The motherboard is the part that is non-standard.
    May 2008
    Lubbock, TX
    Quote Originally Posted by CraziFuzzy View Post
    Yeah thats what really makes me mad right now. I guess Ill just wait awhile and order one with atx power connection and use this MB for my MCPC.
    May 2008
    Lubbock, TX
    I was able to jump the ATX connector and solder a 12v power to the leads on the PSU. My only problem now is that the PSU sees the computer as always on now and does not send it a power on command when the car turns on.
  1. How do I connect my 4 displays to power?
    By HiJackZX1 in forum LCD/Display
    Last Post: 03-12-2008, 05:20 PM
  2. FAQ: Will <insert PSU model> Power Supply work with my system?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 10-10-2006, 12:38 PM
  3. Replies: 0
    Last Post: 12-08-2005, 10:41 PM
  4. Arise PSU problem!
    By mobileh1 in forum Power Supplies
    Last Post: 06-25-2004, 10:14 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
