Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Smart Key
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Sonicxtacy02 View Post
    imagine how annoying that would be to not only have to go into your pocket but also into your wallet to get your key out
    That's why you dont take it out
    Both our Toyotas (well 1 Toyota and 1 Lexus) have smart keys. It is awesome. Just walk up to the car and it unlocks, sit down and press start and it goes. Get out of the car, press the lock button on the door handle and walk away. Easy and awesome.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Jun 2010
    Quote Originally Posted by 2k1Toaster View Post
    Exactly!! It's a no brainer with the smart key. I just wish I knew how to hack it / play with it.
  3. #13
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    How do this work with leather gloves on?
    Is the current the smartkey send, strong enough to go through body and a second layer of thick skin (the leather).
    I live in Norway, and winter times gets freezing cold. Would hate to take my gloves of, just to unlock the car.
  4. #14
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    It doesn't work that way at all....its an RFID tag...just sends a short range radio signal so when you stand next to the car it can detect the key and allow you to unlock the doors
  5. #15
    Mar 2006
    The SKS however is induction based on Toyotas. So with the key in detection range, as long as something like your hand is between the handle and car it will unlock.
  6. #16
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Since when? I just drove a camry hybrid the other day that used an rfid key (key was actually in someones purse). What genius engineer would think an induction based system would work in anything other then hot climates?
  7. #17
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    The Toyota system is active RFID, not passive (which relies on inductance), and has a significantly larger range than passive.
    RevFE
    My Shop
  8. #18
    Mar 2006
    Two completely different things here... The starting of the car and proximity detection are RFID based. The unlockingby putting your hand between the car and handle is inductive. it works everywhere all the time. Both systems work at the dame time. The car actually polls continuously until something identifies itself and sends s coded message back. Then it is constant RF blips until the car is started.
  1. Replies: 49
    Last Post: 11-10-2009, 04:02 AM
  2. Turning key from ACC to Crank = Laptop will standby
    By l00kster in forum Power Supplies
    Last Post: 11-15-2007, 02:27 PM
  3. Hot Keys and Front ends
    By Scorpnstail in forum Software & Software Development
    Last Post: 02-24-2007, 04:29 PM
  4. NaviVoice v.6 RELEASED!
    By 0l33l in forum PowerVoice
    Last Post: 10-11-2004, 01:34 AM
  5. Simulate key press right before shutdown
    By Jake in forum General Hardware Discussion
    Last Post: 12-05-2002, 05:57 PM
