Results 11 to 20 of 23
Thread: VGA cable shorting PC?
  1. #11
    Jul 2009
    B.C., Canada
    It does it even when the truck is running.
    Based on my specs the OPUS 360W should be able to put out more than enough power, especially since the monitor is 9W and I unplugged 10W worth of USB devices alone when I was troubleshooting but I'll give it a shot right now and see what happens.
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
  2. #12
    Jul 2009
    B.C., Canada
    Well, I tested it with the cigarette lighter and it works. I guess that's good and bad news. Why wouldn't my PSU be good enough to start up the monitor?
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
  3. #13
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    maybe its not playing nice with your mainboards power switch wires to power supply or however you have it wired, i just ran a separate switch to my mainboard. mine is a manual system. i keep forgetting to mention i have 07 150, and where in bc you at? SNO
  4. #14
    Jul 2009
    B.C., Canada
    Kamloops.
    This is getting absurd. I noticed I get the 3 flashes on my OPUS when the monitor is connected which means that I'm trying to draw more power than the OPUS can output. I don't understand this at all because on the 12V rail I'm only drawing about 5.5 amps and the 360W is supposed to max 15A
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
  5. #15
    Jul 2009
    B.C., Canada
    The cigarette lighter power adapter that came with my touchscreen has a "power filter" on it. Is that the equivalent as regulated power? If it is I'm just going to tap into the cigarette lighter, if not I really want to figure out what the problem with this PSU is.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
  6. #16
    Jan 2008
    it is not equivelent to regulated power, but will filter out most of the problematic voltage that might mess up the screen picture.
  7. #17
    Jul 2009
    B.C., Canada
    Well it would appear as though it doesn't matter anyways because now when I have my monitor connected to the cigarette lighter it blows the fuse. 0.75A worth of current blowing a 20A fuse. AHHHHHHH!!!
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
  8. #18
    Vendor - Qube colin's Avatar
    Dec 2006
    Your LCD is probably grabbin a bit more than 0.75A then if it's blowin the fuse. I feel like the lighter should have more than 1A spare. Also, plugging in a monitor (12v) that draws 9watts is NOT a good comparison to "several USB devices" (5v) and 10watts. They draw power from different lines. Each line has a maximum. I bet your 12v line is maxed out and your LCD is drawing more amperage than it claims to turn on.
  9. #19
    Jul 2009
    B.C., Canada
    Ya, I realised that after I posted.
    The only 12V devices I have are my CPU which is 45W (3.75A), Mitch's Sirius box which is 12W (1A) and the touchscreen which claims to be "<9W" so ~0.75A and whatever the HDD uses. Everything else is 5V USB devices. That is a total of 5.5A. The 360W PSU is supposed to be able to handle 15A*12V = 180W.
    Even if the touchscreen requires more power to initially start up, it wouldn't be that much more.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
  10. #20
    Dec 2006
    Perhaps your power supply is defective? Or extremely over rated? The HD usually grabs around 1A at 12v and 1A at 5v to spin up. That's now 6.5A. And the 15A, thats probably a fuse rating, so that's minus inefficiencies. I'd vote defective if it can't put out 10A.
  1. Fan Control??
    By STI_FFY in forum General Hardware Discussion
    Last Post: 08-23-2009, 05:02 PM
  2. Fan placement on case and screens!
    By HiJackZX1 in forum Fabrication
    Last Post: 06-04-2008, 07:12 PM
  3. screen alternator whine caused by pc fan!?
    By m60power in forum LCD/Display
    Last Post: 04-30-2008, 11:32 AM
  4. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
