Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: VGA cable shorting PC?
    Jul 2009
    B.C., Canada
    I've read several posts about something similar to this but not quite at the same time and none of those suggestions seem to help.
    My PC works beautifully on a desktop ATX PSU. In the truck the computer seems to boot properly when the monitor is not attached but as soon as I attach it the CPU fan spins then quits over and over again.
    My guess is it's either the power or ground going to/coming from the monitor but I checked all of my connections and everything seems fine but, I'm not sure exactly how to test everything.
    I have an OPSU 360W PSU so I have lots of power.
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jul 2009
    B.C., Canada
    UPDATE:
    To eliminate some possibilities I connected just the power to the monitor and turned on my truck. Everything works as normal, so I tried connected the VGA cable to the monitor while the PC was running and the PC instantly shut off. I know there's a short somewhere, I just can't see where or how to fix it.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jan 2008
    it sounds like you have eliminated everything but the monitor-- would it be possible to try it on a different computer?
    Jul 2009
    B.C., Canada
    In an awkward round-about way that involved a 12V AC-DC brick and a spoon (don't ask), I managed to test in with my laptop and it worked perfectly fine.
    What in my truck could be causing the short?
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jan 2008
    a vga extension cable?
    Jul 2009
    B.C., Canada
    None being used. I'm using the exact same cable in the truck as I tried in the house.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jan 2008
    ok, so now i have to ask: what was the spoon for??
    Jul 2009
    B.C., Canada
    Haha. I'll accept your question and use it as a bump.
    My touchscreen is molded (kind of) into my bezel from the truck and the way I put it together plus the fact that I didn't want to crimp the AC-DC power supply to my monitor power wires, the only way I could put it together was face down. If I moved it the wires probably would have come loose. Needless to say I couldn't find a small mirror but have very shiny spoons. Everything was upside down and circus mirror like but the monitor did work from my laptop.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Jul 2009
    B.C., Canada
    UPDATE:
    I brought the entire PC into the house to check and it works fine on my regular LCD monitor so I connected the touchscreen to the truckputer inside and it works fine. What gives?
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    It sounds like drawing too much power and reboot cycling, when i am doing updates in my driveway with engine not running i need to connect charger on 10amps to keep from reboot cycle. Can you power monitor via lighter socket and connect vga to comp? SNO
  1. Fan Control??
    By STI_FFY in forum General Hardware Discussion
    Last Post: 08-23-2009, 05:02 PM
  2. Fan placement on case and screens!
    By HiJackZX1 in forum Fabrication
    Last Post: 06-04-2008, 07:12 PM
  3. screen alternator whine caused by pc fan!?
    By m60power in forum LCD/Display
    Last Post: 04-30-2008, 11:32 AM
  4. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
