Results 1 to 10 of 15
Thread: At A Loss - Master Volume Control
    Jun 2010
    I am at a loss trying to figure out how to integrate a master volume knob into my setup. I plan to use the Joycon for my steering wheel control, but I'd like to maintain a master volume knob too.
    I have read various searched threads on using preamp and EQs that have remote volume but I just don't understand how to set up a system to achieve this along with the joycon.
    I plan to use an internal HD sound card for 5.1 sound. Out of the SC, I will run to each one of my amps for the speakers. Joycon can control the FE / Windows volume but what volume knob would work and how to add it. I am only guessing that I would need to plug it into a fusion brain or something? Please help me understand.
    The best forum start place is here but damned if I could find it. I had spent several weeks on the forum before finding it.
    Jan 2008
    The joycon is basically a 'simper' FB-- it looks for a certain resistance(each button has it's own resistance that is connected to it), and tells the computer when it sees it, and the software defines what happens on the computer when that button is pressed.
    If you are looking at using a external physical knob as well, then you might run into problems-- ie. You will end up having to set 2 different volume knobs.
    It might be better to try to see if a qube/fusion brain will work better for you-- because I believe that either should allow you to have 2 software volume controls that will not affect each other the same as a software and physical knob arrangement.(though I have no experience with either product, so you should check that it will work before buying one on my advice)
    Jun 2010
    Thanks for the input. The more I think about it, the FB is prob the way to go with it. Anyone else have any ideas?
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    3RVX
    found this neat little program to change volume and eject via hotkeys
    I'm workin on using an Arduino to send key-presses to windows
    Colin's Qube will be next
    i don't know much about FB
    what kind of physical volume knob are you planning on using? i might suggest not using a regular ol' pot (comp sound > pot > amp > speaker)
    there is also a small board called U-HID, which sounds allot like the JoyCon, but i don't have any hands-on with ether.
    Jun 2010
    Sleepy, thanks for the info. I am really still in the design phase and without knowing how it would all fit together, I don't know which knob I'd use. The farthest I have gotten is that it would have to be one without physical stops.
    If I understand you correct with the comp sound > pot > amp > speaker comment... I ultimately want the knob to control the windows volume level the same was as a FB or Joycon would. I do not want the master volume to change the input levels into an amp.
    Vendor - Qube colin's Avatar
    Dec 2006
    For the record, I already have all of this done via my Qube. My site is down right now (data center switching) so I can't link to it, but I have software that takes a rotary encoder (knob without physical stops) and changes your master volume in Windows Vista. I'll update this in a few hours with the link.
    Jun 2010
    Collin, please post a link when your IT issues are resolved. I am interested in what solution you have.
    Dec 2006
    Server might be down for a while. Here's some pics for the hell of it.
    1) software
    2) encoder prototype
    3) encoder board
    Dec 2006
    Oh, there's also a MUTE function if you click the encoder in.
    Feb 2010
    hey Colin,
    have you used your Qube to read steering wheel controls yet? There shouldn't be any difficulty with doin that, but the rest of us are still noobs to your Qube.
    BTW is your final encoder there smooth or are there steps to it? and what is the shaft size? cause i've been diggin up some rather spiffy knobs
  1. Soarer Volume Control
    By Beezer in forum Hardware Development
    Last Post: 03-11-2012, 11:47 PM
  2. Volume control on PC or headunit?
    By efun in forum Car Audio
    Last Post: 01-15-2009, 09:48 PM
  3. M-Audio with ASIO volume control
    By mkysimes2 in forum Road Runner
    Last Post: 04-16-2007, 11:25 PM
  4. Volume Control
    By storm in forum FrodoPlayer
    Last Post: 06-27-2004, 12:02 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
