Results 1 to 3 of 3
Thread: mounting a blackbox-n case
    Newbie HAVOC's Avatar
    Jun 2010
    Connecticut
    Question mounting a blackbox-n case
    Are the holes on the side of the case supposed to be double din ISO standard?
    Meaning, I unbolt my factory radio and use the factory screws and brackets to install the blackbox case?
    Is just the double DIN size a standard, and you need to drill holes in the case to mount it?
    Elsewhere
    Only the size is a standard. Mounting methodology is not, as far as I know.
    How about the Wiki?
    Dec 2003
    I had to drill new holes for mine to mount it in my Toyota Yaris double din space.
    I also found that the front piece around the screen was slightly larger than double din and i had to do some adjustment to the dash so i could mount it flush instead of hanging out the front.
  1. siLABS RADIO PLUGIN
    By 307SW_NLD in forum RR Plugins
    Last Post: 07-26-2008, 10:11 AM
  2. Hardware Review: Mobile Computing Solutions Mini-ITX case
    By Dingo509 in forum The Review Palace
    Last Post: 12-06-2007, 08:25 AM
  3. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  4. Replies: 1
    Last Post: 08-21-2005, 01:16 PM
  5. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
