whats LVDS interface?
COMMELL LV-670M
This thing's almost perfect:
- LVDS interface.
- Mobile Pentium 4 (not a big hot desktop CPU).
- Intel chipset.
- USB 2 and Firewire.
- SPDIF digital audio out, 5.1 suport.
- DiskOnModule / Flash Disk support.
If only it had digital audio in, and RCA analog audio connectors instead of mini connectors. (I don't get why manufacturers are making these so-called "hi-fi" motherboards that use mini audio connectors instead of RCAs.)
Main drawback is that this isn't meant to be a retail board, so it probably won't be cheap.
As seen on mini-itx.com.
Yes, almost...no serial...Originally posted by billthecat
COMMELL LV-670M
- LVDS interface.
- Intel chipset.
As seen on mini-itx.com.![]()
Try to find a US source and price.... This has been the topic of several threads on Sudhian Forums.
TruckinMP3
Read the FAQ!
LVDS means Low Voltage Differential Scsi, but they are using it in the context of video here, so there must be a new meaning.
almost the sameOriginally posted by eugenen
Low Voltage Differential Signaling
Yea, acronym overload. When I read LVDS I kept looking for the scsi card specs. now we have to specify if its scsi or video![]()
LVDS=LCD controller onboard in this context. Meaning this board can directly interface with a bare LCD (all you need is an inverter for the backlight).
Check the specs again. There's one serial port.Originally posted by Defiler
Yes, almost...no serial...![]()
I don't see it in the picture, so there must be headers for it somewhere on the board.
