Results 1 to 3 of 3
Thread: power problems
    Nov 2000
    Post power problems
    Ok here is my situation.
    I have a 200mhz pentium with a 20 gig HD
    hooked up with a 140 inverter hooked up the cig. lighter.
    When It seems at times when I use my brakes (brake lights)
    the power cuts out for a moment and makes my computer restart.
    has anyone encountered this problem
    and no of a way to fix this.
    Do I need to wire my inverter directly to my battery?
    [This message has been edited by ordlay (edited 12-01-2000).]
    Apr 2000
    Little Rock, Arkansas
    Post
    battery is about to die or your alternator is going bad. Same thing happened to me expcet that it was when i put on my turn signal on while i was running the AC. I ended up having to replace both though acuse the guy at autozone told me it was the battery and sold me a new one, then a couple days later, my batter was dead for no reason. Took it to an alternator shop and he had to rebuild mine. At any rate, replacing both took care of my problem. I guess its kinda a warning to your battery dying, isnt a bad thing really.
    Grand aMP3
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    You know if it wasn't so tragic, it sure would be funny. ;0)
    http://www.geocities.com/mr_bubba_zanetti/
