Results 1 to 9 of 9
Thread: Options for powering router that uses 9V DC?
    Jun 2008
    Perth, Western Australia
    I am looking at getting a USB 3G dongle for my car computer, and I don't really want to run it on the computer itself.
    I was looking at using something like the TP-LINK TL-MR3420 that can do the 3g sharing, and has wireless as well, so I can set up a mobile hotspot, and have my computer connected to the net.
    But, the power brick on this unit outputs 9V DC, not 12V like most other routers.
    So, do you think I could run this model on 12V regulated (use the M4-ATX 12V to run the unit), or is there a circuit I could solder up that would drop the 12V down to 9V to power this system?
    I would be powering it off the M4-ATX, as that way it starts and stops with the computer, so it wouldn't drain the batteries.
    This model comes in at $89AUD, so if there are any other units that are around the same price and take 12V (Or even have Gig eth ports!!), what options are there? (Don't mind ordering from the states or elsewhere either!).
    Raw Wave
    Nov 2009
    Stick to 9V unless you want to risk damage.
    Chances are it drops to a lower voltage internally....
    So you are going to have other PCs in or near your car to connect via your 3G?
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    DCL11-xx point of load power supply right here at the MP3Car store. Description suggests it's 5V only but look at the manual...
    http://www.mp3car.com/products/Power...er_20Guide.pdf
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Raw Wave
    Nov 2009
    All that for a mere 15W output?
    It doesn't even step-up.
    Jun 2008
    I was thinking more along the lines of being able to drop it via resistors soldered inline with the power lead?
    If its using the clean 12V from the M4, wouldn't I just be able to knock that down to 9V by adding resistors? Or is that too much of a drop?
    The other option is waiting until I can get hold of the router, and once I strip it, I can find out what voltage regulator is on it, and check the datasheet, see if it will take 12V input.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    i just found a 9v 1.5a cig charger and cut the end off put in project box and wire to car 12v fastest solution i could find for my in-car 3g wifi router and was cheap too 10 bucks just my 2 cents SNO
    Raw Wave
    Nov 2009
    Quote Originally Posted by Chester View Post
    Only if is it is a constant load, and a constant supply (ie regulated).
    I suspect you don't have either.
    Jun 2008
    Quote Originally Posted by OldSpark View Post
    I think you might be right there too!! hehe
    Ok, will have a look for what SNO suggested, see what options there are, at least I don't have to rush this part, as there will be some fab involved in it (going to remove the LED's off the router and extend them into the dash for feedback etc).
    Thanks for the input all!
    Jan 2008
    Dartmouth, MA
    Definitely just go to radio shack or something and pick of a 9 volt lighter adapter. Definitely enough power for a router, and definitely, the cheapest way.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  1. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  2. Replies: 14
    Last Post: 02-11-2005, 07:35 PM
  3. DC to DC converter
    By jdub421 in forum Power Supplies
    Last Post: 02-03-2004, 04:17 AM
  4. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 05:25 PM
  5. atx dc dc
    By tre in forum General Hardware Discussion
    Last Post: 12-17-2000, 08:24 PM
