Results 1 to 5 of 5
Thread: Clean deep bass with least amount of rattling, what box to build?
    Constant Bitrate Seabass's Avatar
    May 2003
    Hey everyone, I was wondering what kind of box i should make for my 1 rf 15" with 800wattrms rf amp? I want nice clean loww bass, and can someone please explain to me what type of sound ill get from different boxs? Im gonna either get a sealed facing the back or front OR Downfire(down) OR get a ported faciing the back or front, which one you think? Thnx. Btw i want my crap not to rattle my car, its a toyota camry and i want a setup that will minimize rattling and has real nice deep bass. Thnx
    -Seabass
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Well if you are going to build your own box, One recommendation I can give you is once done, seal it with fiberglass resing. No air will be leaking. Give it a couple of coats. You'll be cooking.
    Constant Bitrate Suprapc's Avatar
    Apr 2003
    Scott, La
    Check out
    http://www.jlaudio.com/tutorials/index.html
    for speaker tutorial.
    Specifically
    http://www.jlaudio.com/tutorials/magic/index.html
    For box designs
    Don't worry about perfectly sealing the box unless you are putting out some serious sound. I've never seen any difference.
    Definitely make sure your box is STRONG. I'm personally a fan of sealed box due to its small size however it isn't very efficient or loud.
    2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
    Aug 2002
    Eau Claire, Wi
    from my own experience the best bass does come from a sealed box. from the ones that ive heard ported boxes seem to muffled bass. as for being loud, you might have to drive them slightly harder but subs in sealed boxes can pack a punch. i have 2 600 watt MTX 10's in sealed boxes in my f150 and wow. thats some bass.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Aug 2002
    Eau Claire, Wi
    one thing i forgot to mention, i custom built my sub boxes to exact specifications set by MTX. if your making your own boxes or even buying them, the exact amout of air volume inside the box does matter. and if you plan on using that polyfill stuff in the box that also needs to be taken into effect as it simulates a larger box.
