Results 1 to 9 of 9
Thread: connecting imac slot load drive
    May 2003
    Ok, can someone tell me how to connect an imac drive to work with IDE connector on a pc.... The drive has the original imac adapter. Heres a pic:
    I want to do it like that, do i just connect a 40 pin cable on the adapter then solder power like it shows?
    Aug 2002
    Eau Claire, Wi
    yep, just like the pic shows, it works great.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Dec 2001
    my parents house ;-)
    how come mine's different on the right side?
    I could just solder power to the pad on the right????
    May 2003
    ii think you would solder to those points between the two black things
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Looking at the pics...the power is further right than the second pic shows.
    Those black things are probably fuses...so no you wouldn't want to try and solder to them...just look at the right edge...
    What was your source for this drive...me likey
    May 2003
    who you asking? i got mine from ebay
    May 2003
    inline4, my cdrom looks the same as yours, tell me how it goes if you decide to solder it
    Dec 2001
    well i dont know if the board is any good. I know the drive is.
    I smoked (read melted) the cable because i read the pinouts wrong... eek.
    May 2003
    ide cable? or power?
