Results 1 to 5 of 5
Thread: Directed DMHD-1000 setup help
    Low Bitrate atrixstars's Avatar
    Oct 2006
    hi, I have an Directed DMHD-1000 HD Radio. I connected the radio to (constant, ign, ground) and to antenna in. It doesnt turn on, does anyone know if I am missing something?
    thanks
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    Okay, any more specific info?
    Do you have the Directed display module? Is there a harness that came with it, or did you wire it up yourself? If you don't have the little display/control box, you need to use the Serial Port cable that MitchJS provides (or make your own, or whatever). That's what tells the unit to turn on.
    Some more info will probably help get the correct answer to your problem. Be as specific as possible as to settings and wiring and stuff.
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
    Oct 2006
    This is an brand new or like-new unit. It comes with all the wiring with the control module. I tried pushing and holding the power button on the control unit and does not power on. I also tried the remote and no power. I checked the (constant, ign, ground) they have power and proper ground.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    check the 2 fuses...the one inline with the red cable and the other inside the small black box inline with the yellow cable
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Make sure there are no bent pins on the DIN cable.
  1. Centrafuse 1.2 won't leave setup
    By marchello2000 in forum CF Bug Reports
    Last Post: 07-03-2007, 12:18 PM
  2. Power wire and distribution block setup
    By skiWVUxtm in forum Car Audio
    Last Post: 03-06-2007, 09:11 PM
  3. Need help decoding a one wire databus...
    By Dexter in forum Hardware Development
    Last Post: 03-04-2006, 09:09 PM
  4. Replies: 0
    Last Post: 03-20-2005, 02:34 PM
