Results 1 to 7 of 7
Thread: Powering this MoBo, will the OPUS do it?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I was wondering if my OPUS 320 will power this thing.
    http://www.newegg.com/Product/Produc...82E16813130255
    I notice that the connector on the mobo for the power has 24 slots. The Opus 320 only has 20 slots/pins. Will it still work? What exactly is the extra connector for?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    i found a good link about the subject for you, http://www.smps.us/20-to-24pin-atx.html the only thing i can think of that might also be a problem is the 4 pin molex connector near cpu for the extra power the cpu needs hope this helps SNO
    Low Bitrate eigenVector's Avatar
    Apr 2009
    My new asus mobo requires the 24-pin atx as well. The opus 360W I have includes two four-pin connectors, one that slides into position along side the 20-pin one to form the 24-pins (there are two little notches on the side of it to help line it up), and the other that connects to the other 4-pin molex.
    I'd be a little suprised (although not too suprised) if your 320 didn't come with both of these connectors.
    Edit:
    The 250W,320W and 360W user guides all point to the same 250W user document here (Image J9). This seems to indicate that it does have a 24-pin connector. You should have the 20-pin, so just line it up with the 4-pin one I mentioned above.
    Elsewhere
    As far as the connectors, that is an easy remedy if the Opus doesn't have them. There are adapters to physically connect everything if the PSU doesn't include them.
    And as far as supplying power, the CPU is the biggest determiner of power draw, not the motherboard.
    You know that, HiJack.
    How about the Wiki?
    Jul 2007
    Miami
    Quote Originally Posted by SNOtwistR View Post
    I think I recall the OPUS 320 having the CPU Molex connector, but I dont remember it having the extra connector that slides in next to the 20 pin connector. I dont know because I modded my OPUS. I think I am going to have to order a new cable from them.
    Quote Originally Posted by eigenVector View Post
    Edit:
    The OPUS 320 didnt come with them. The picture in the instructions shows a 24 pin, but thats the part that connects to the OPUS itself, not the part that connects to the MoBo.
    Quote Originally Posted by DarquePervert View Post
    Yea I know...... A Core2Duo uses about 65W..... Thing is the manual says that it require 350 watts power. I also want to add 2 PCI graphic cards, 3 USB hubs (which are powered externaly by another device) and the USB to VGA (which has a tiny power draw). I cant seem to find the wattages that the 2 graphic cards use, but I do not think much, since they are old school.
    http://www.tigerdirect.com/applicati...1685&CatId=696
    If anything, I could always update the card to the OPUS 360, but Im scared that even that is not enough. Do you think the 350watt rating is just a random number they throw out?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jan 2008
    there is always a point to why they want certain hardware, but there is other factors, or equipment that they might have assumed the end-user would have that you will not..
    also, keep in mind that 350watt ac-dc power supplies are some of the most common, cheaper power supplies out there, so this could have also been part of the concept of the recommendation..
    it looks like those graphics cards are bus powered-- i don't see any sort of power connections on them.. so you could try to determine the max allowable draw from a pci port, and then use that as a rough estimate..
    Jul 2007
    Miami
    Quote Originally Posted by soundman98 View Post
    Thats a great idea..... I guess what I can do is build the system and try to power it with the OPUS. If I cant then I know we will need more power.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Will this work? Powering Opus
    By dmurray14 in forum General Hardware Discussion
    Last Post: 01-02-2006, 01:17 AM
  2. Inverter to hard drive , Opus Mobo
    By naveedh in forum Power Supplies
    Last Post: 01-10-2005, 06:39 PM
  3. FS: Bunch of carputer parts (opus, mobo, amd2000xp, ram, etc)
    By wizawuza in forum Classified Archive
    Last Post: 12-05-2004, 10:28 AM
  4. Opus not powering on VGA/Sound
    By TheGeneral in forum Power Supplies
    Last Post: 10-04-2004, 02:01 PM
  5. Powering Lilli with Opus
    By muldrick in forum LCD/Display
    Last Post: 08-27-2004, 03:45 PM
