Results 11 to 20 of 22
Thread: Question about how SSD handles cold weather
  1. #11
    Newbie piglith's Avatar
    May 2008
    If you can find one. You need a small silicone heating pad/tape. 12v sized to the size of your SSD. Then you can wire direct with switch. Flip switch on for a few min to warm up the SSD then good to go.
  2. #12
    May 2005
    San Clemente, CA
    Quote Originally Posted by Bugbyte View Post
    If they have similar characteristics to PC RAM, then they should do quite well in the winter.
    QFT. It will work as well as any other piece of silicon at sub-zero temps. In others words - really, really awesome. There is even the freezer trick to rescue FDB drives.
    Quote Originally Posted by Curiosity View Post
    So you could probably assume a little beyond those numbers, but at -40 I'd think it might reduce the life heating and cooling down often.
    Cold will extend its life. Haven't any of you ever visited an overclocking forum? http://forums.extremeoverclocking.co...d.php?t=137454
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
  3. #13
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    LOL. No, there's a difference between freezing and compensating for heat. Overclocking to 49GHz raises the core temp to melting temperatures in microseconds. Having a constant supply of -200C directly on the heatsink keeps it from burning up. It's still running quite hot. They didin't say how long it lasted did they? But yeah, everything around that is subjected to stress when heating up and cooling down and that's -200C so it would be a good example of extremes if we knew.
  4. #14
    May 2005
    San Clemente, CA
    Cold prolongs the life by reducing damaging electron migration and the effects of the voltage running through it. Processors don't "melt." Liquid nitrogen is even used to cool some supercomputers 24/7. Bottom line, cold by itself is nothing you have to worry about with electronics.
  5. #15
    Low Bitrate eigenVector's Avatar
    Apr 2009
    I owned a OCZ Summit that worked fine in winters here in NC. Booted up around without issue on 0C to -5C mornings.
    I updated it with a Vertex 2(Edit... this is just a first gen Vertex, not a vertex 2.), and this winter has been issue after issue. It just does not boot up when it's < about 5C. I get an error booting into windows, and have to keep the PC on for about 5 minutes until it is warm enough to boot. I had also updated the motherboard at this time, so it may not be the drive itself and may be the storage controller. I may have to try and swap the summit back in to see for sure.
  6. #16
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by eigenVector View Post
    I updated it with a Vertex 2, and this winter has been issue after issue. It just does not boot up when it's < about 5C. I get an error booting into windows, and have to keep the PC on for about 5 minutes until it is warm enough to boot. I had also updated the motherboard at this time, so it may not be the drive itself and may be the storage controller. I may have to try and swap the summit back in to see for sure.
    Same with me - also with a Vertex 2. This is the first winter with this drive. My old WD sata drive worked fine for the past two winters.
  7. #17
    Apr 2009
    Correction... I thought the drive I had in the trunk was a Vertex 2. It's a first gen Vertex.
    Also, upon further investigation, my situation has gotten weirder. We had a very cold week this week with lots of snow, and the temperature barely reached above freezing. During this entire time the drive had no problems booting into at all. The weekend came and the temperatures reached just above freezing, and immediately I am encountering problems getting the drive to work. I keep getting a disk read error, or on occasion a 'missing operating system' error. I let it warm up for about 5-10 minutes, and it boots up just fine. It seems there's either something else going on, or the drive just doesn't like being slightly above freezing. I'm doing a full disk check now while it's operating successfully to see if it comes up with anything. I still may just switch back to the Summit.
  8. #18
    Oct 2006
    thats very strange, because i own a first gen vertex as well, and this is the 2nd winter its been in and absolutely no issue whatsoever. Temp around here is +35*C to -35*C or even lower at rare occasions.
  9. #19
    Apr 2009
    Quote Originally Posted by Punky View Post
    Thanks for the response. Perhaps something else is going on after all. I ran a full check disk on it and it came back with no errors. Performance benchmarks are just as good as ever. I did upgrade motherboards since using the Summit so perhaps something is going on with it or maybe I've just got a weird vertex.
  10. #20
    Oct 2006
    i would put the summit back and see if the problem still exist. if it works fine with the summit, then you might have a faulty vertex.
    then i would try a different vertex drive to see if the problem still there.
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
  2. Intel x25-m SSD - has anyone tested it in cold?
    By leman in forum General Hardware Discussion
    Last Post: 12-23-2009, 03:55 AM
  3. Cold weather lock up problems
    By theforce in forum General Hardware Discussion
    Last Post: 12-26-2008, 04:56 PM
  4. has anyone tried this SSD
    By drutort in forum General Hardware Discussion
    Last Post: 08-08-2008, 03:02 AM
  5. Cold Weather LCD Question
    By rodgers412 in forum LCD/Display
    Last Post: 02-10-2007, 01:19 AM
