Results 1 to 7 of 7
Thread: summer temperatures.
    Dec 2001
    my parents house ;-)
    its getting pretty hot. what do you guys do to keep your lcds and systems cool?
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    My truck has Air Conditioning...
    Other than that it has not been a factor in 100+ heat for the last couple of years.
    Dec 2001
    hahah isnt dfw texas?
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Re: summer temperatures.
    cooling isnt always based on air temperature...(although it is easier to cool something with cold air)
    moving a larger volume of air over a heated surface will generate a better cooling affect than a small volume of air over the same surface...
    what that means to the non-mechanical engineers... put in more fans, or fans with higher CFM ratings. let your case breathe better...
    basically think about air movement. stagnant air will heat up along with the electronics and basically prevent any cooling from taking place due to air movement.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    its all about the airflow.. get good airflow and you won't need to worry about the temps outside.
    '98 Explorer Sport
    80% done
    Oct 2000
    DFW area
    Yup TX.
    I agree with all the above, as long as you can have air moving (or able to move) past your heat sources...amps...powersupplies...cpus etc.
    So don't stick it in a seat cushion...but you could probably put it under a seat, given enough room for air exchange.
    FLAC Gutter's Avatar
    Dec 1999
    Casina, Italy
    hijinks is correct. If it's very hot, the computer in the trunk will sometimes freeze up or the amp will cut out because it overheats. If I lay the backseat down, it'll run fine.
    Figure out a way to get some airflow to it. It doesn't have to be particularly cold air either.
