I'm really not trying to be rude, so please take no offense to this. Do you have any friends that are more computer savvy ?
You may want them to come over and show you how to reformat and re-install.
try the disk on your other machine, so you know if the problem is the disk or the drive
[H]4 Life
I'm a lesbian too.
I am for hire!
Ok i will thanks
That's the most civil answer I've ever seen after someone tells someone that, thanks for taking it in good faithOriginally posted by andrew8485
Ok i will thanks
[H]4 Life
I'm a lesbian too.
I am for hire!
Ok i had someone look at it for me to day and he said that it is not dectecting the hard drive he said the cables look like they are conected right on singledrive an fliped the right way. he says i probly have to set the rocker swithes on the motherboard to the right pci bus speed. he did not know what to set it at. i read online if you set it at 37mhz or less it and it will work is this true. I know this hard drive is good thanks
