Results 1 to 10 of 16
Thread: Which harness to use for Ford Focus 2006? Advanced/Standard?
    Sep 2010
    Hi,
    I just bought one of the all-in-one Chinese 7" 2 Din unit thingos. Just wondering if I will need a standard ISO harness for my car or one of those advanced ones? (I think they have RCA connectors but not sure). The unit comes with both the standard ISO and RCA connectors so I'm not sure which one to use.
    Thanks,
    Sam
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Sep 2010
    Yeah I have been looking at similar ones to that but I would rather not do the wiring/soldering. Maby something like this?
    http://cgi.ebay.com.au/Ford-stereo-I...item3cb12232a4
    Elsewhere
    You will need to connect all the wires from the harness for your vehicle to all the wires from your headunit.
    If you have issues connecting wires together, you might consider having a professional install your gear.
    How about the Wiki?
    Sep 2010
    Yeah which is why I was thinking about going for the second option. The unit comes with an ISO harness so it should just plug right in yeah?
    Jan 2008
    there is no standard connection type in car audio. every manufacturer uses their own style of connectors, so you must connect the wires together from the adapter harnesses to get the correct configuration for your purpose.
    Sep 2010
    Ah ok fair enough. Do you suggest just wiring the two directly together to crimp some sort of connector on?
    Sep 2010
    Sorry but I don't quite understand.
    I do realise that each car manufacturer have their own wiring but I thought these wiring harness adaptor converts this into a standard male/female plug that can be plugged into another unit using the same standard male/female plug?
    Jan 2008
    the ford-specific connector in your car should be completely different from the chinese unit's connector...
    you should be able to get a adapter cable for the ford harness+ connector, and the chinese unit should include connector with the wires hanging off it-- you would need to connect those 2 harnesses together.
    butt connectors are common for this-- just make sure to fully crimp them so they don't fall apart later on. otherwise, i prefer to solder my wire connections.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by sam0433450 View Post
    I get what your saying and yes, some companies do the work for you and sell for example a Ford harness already mated to a Pioneer harness but I doubt your going to find one for your puter as stated by Soundman.
    Also, no offense, but maybe Darque is right: if you are that relucant to do one of the most basic functions of upgrading any radio in a vehicle, should be messing with it at all?
    Maybe paying someone is the right way for you to go. If you have friends that do this stuff, beer can go a long way to getting help just wait until it's in and working before offering too much!
  1. 07 Chrysler 300 Limited - In Dash PC
    By BCasey in forum Worklogs
    Last Post: 07-24-2012, 10:27 AM
  2. Ford Focus 2006 Double Din Fitting
    By sam0433450 in forum Newbie
    Last Post: 11-08-2010, 09:41 PM
  3. Need Advice on LCD for Ford Focus 2006 230mmx120mm
    By sam0433450 in forum LCD/Display
    Last Post: 09-23-2010, 02:09 AM
  4. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
