Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Remote start - with a manual trans - a.k.a. "the jealousy thread"
  1. #11
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    The parking brake must be on in order to get to step 3. The system must see a negative signal from the parking break switch. If you get to this point and try to get out of the vehicle with it running and in gear it is going to stall. This will cancel the ability to remote start until you reset it. The fact that the remote start will not function if the alarm has been tripped eliminates the chance that someone could get in to the vehicle and put it in gear.
    I'd say there are more failsafes with this setup than on a remote start for an automatic.
  2. #12
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by txspazz View Post
    This Clifford Matrix 20.7X looks pretty awesome. The manual isn't online at cliffords website though. I'm guessing I can't program it via the computer like the G4/5's, but not that big a deal. It states a "manual transmission mode", and is just a remote starting unit. There's an alarm system(OEM) that comes with my flavor of mustang from that year already has a passive system with vibration and the like, so really don't need the extra alarm features of the G4 and 5. So long as this can tap into the existing OEM for whatever the trigger-line might be, it should be good, I'm not sure if this will clone my existing remotes correctly, and such.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
  3. #13
    Raw Wave
    Nov 2009
    The park brake switch circuit should be easy to bypass - especially if it's a simple oldskool grounding switch.
    If CANned etc, maybe a short across the switch itself - unless sophisticated 2-way or impedance sensitive or optic/magnetic etc switching is used.
    Else a mechanical solution, though that probably means moving the switch further away from the mechanism because it is held "off" with handbrake in/down and is "handbrake on" when the handbrake releases it.
    FYI - many Jap gearboxes have neutral sensors. Thee were added from the late 1970s for pollution reasons. (Hence 2 look-like switches; one is reverse, one for neutral - but one is NO the other NC.)
  4. #14
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    I had remote start in my standard tranny Honda. The whole point of the process 1-5 by listed by Wayne above is failsafe in itself. If you do NOT follow the procedure, you will not be able to remote start your vehicle after (in or out of gear). Because you have to set the e-brake, then "arm" the starter (which leaves the engine running), you cannot possibly get out of the car while it's in gear with the engine running. Then when you get out of the car you have to hit the button again so the engine stops and the doors lock (if so equipped).
    Hope that helps.
    John
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. Remote Start
    By Asian Gang Lord in forum Power Supplies
    Last Post: 12-03-2007, 01:01 PM
  3. Carputer acts weird when I remote start my truck.
    By tbird2340 in forum General Hardware Discussion
    Last Post: 10-17-2004, 04:03 PM
  4. PC remote start - via remote on your key
    By SAScooby in forum Power Supplies
    Last Post: 04-15-2004, 01:33 AM
  5. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
