Results 1 to 10 of 14
Thread: Remote start - with a manual trans - a.k.a. "the jealousy thread"
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Ok, partly because I'm bored at work, and I do have an actual genuine interest; not having to trudge into sub-zero weather down the driveway to shiver inside my car for 40 seconds to start the car and make a mad dash back inside to wait for it to warm up would be nice this winter.
    So.. The obstacles as I see them are:
    1. Check for neutral shifter position.
    2. If I remember correctly this car (mustang 08) has a chip in the key itself I believe to prevent start-up without proximity. How to bypass, or simulate? Not even sure what it is, RFID maybe?
    3. As I know I'm missing something else that probably needs to be here..
    Opinions? Options(Aside from visit the dealer and get an automatic ya smartarses.)? Methods? Anyone else actually done this?
    Would the aurdino be able to accomplish both 1&2?
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
    Sep 2009
    4.remember to leave in neutral the night befor???
    .....and hope its still where you left it???
    Jan 2008
    1. depends on the car-- i remember reading that some vehicles have sensors to tell the cars computer what gear it;'s in(new skyline gtr), others don't...
    2. really easy-- they make bypass modules for this--there are 2 different modules-- one attempts to copy the keys signal, and a trigger wire from the alarm tells it to repeat it.. i could never get the one i had to work correctly..
    the other method is to use a box with a relay, where you put a spare key. when the remote start triggers, it actuates the relay, and allows the chip signal to pass near the cars antenna by the ign switch.. the only problem is that chip keys are $50+, and oyu loose one to your remote start.
    something to know-- my local ACE hardware just started offering a chip key duplication service, where they make new keys-- basically they just copy your old chip 'code' to the new key-- the nice thing is that this is much cheaper then the dealership, so for something like this, you could have the key 'coded', but not physically cut, so that it only works with the remote start..
    3. buy a winter car that is automatic.
    Apr 2009
    Delaware
    Quote Originally Posted by soundman98
    Yeah, that one I don't think is true for mine. I'd have to set something up.
    That might be the way I'd want to go. Don't really want to completely bypass the security measure, not that it deters a pro car thief, but the kid looking for a joyride isn't goin' anywhere. That with the duplication service might be the ticket for that aspect.
    Quote Originally Posted by dawnn
    Nice
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Most Ford's have a neutral safety switch on manual transmissions. Usually unused, but the sensor is still there, at least on vehicles that use an eec-v Ecu. 2008 would have a newer ecu but it might still have that sensor. If you can get a pinout for your ecu and look to see if that line is populated?
    RevFE
    My Shop
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    For additional safety, hookup the (-) neg wire of the remote start module to the E-brake. That what I did with the remote starter on my Supra.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    I've been out of the mustang world for a few years, but, I do not think it has a nutral safety switch. Clifford G5 and G4 (if you can find one) will work with a manual transmission. I don't think they advertise it but it is set when you do the install.
    The key is easy. You can use a bypass module or a relay and a foot of wire. these only bypass it when the remote starter is used.
    I've had G4s and G5s on my past 6 vehicles. Only one was an automatic and 3 were manual mustangs.
    Jan 2008
    ^ so did you leave it in neutral, or was there a way that it wouldn't start if left in gear?
    part of my problem in this is that i used to drive saab's at a local dealership, and the older versions locked the key until you put it in reverse, so i still put manual trans cars in reverse before taking the key out..
    Feb 2008
    TEXAS
    1) Set the parking brake and take out of gear.
    2) Press button(s) on remote.
    3) Remove key from ignition. Engine will continue to run.
    4) Arm alarm with remote and engine will shut off.
    5) press button(s) on remote to start engine.*
    * If the alarm has been set off the engine will not remote start.
    I can understand the habit as I always leave the trans in neutral even when not using the remote start.
    Apr 2009
    Delaware
    Quote Originally Posted by txspazz View Post
    That's awesome. I just searched them out. Is there something to use for fail-safe means though? I've always had a stick-shift car since I started, my habit has always been to leave it in gear, and the emergency brake only gets used on idling or inclines. So you might see how this could concern me a tad.
    Forget about it the night before once, or not otherwise check myself and my neighbor could end up with a car in his living room that morning. I suppose the emergency brake light could be used to make sure it's engaged, but if that's the only realistic means I might have to scrap the idea, as I know I would need a way for the system to check for a neutral gear position somehow.
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. Remote Start
    By Asian Gang Lord in forum Power Supplies
    Last Post: 12-03-2007, 01:01 PM
  3. Carputer acts weird when I remote start my truck.
    By tbird2340 in forum General Hardware Discussion
    Last Post: 10-17-2004, 04:03 PM
  4. PC remote start - via remote on your key
    By SAScooby in forum Power Supplies
    Last Post: 04-15-2004, 01:33 AM
  5. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
