Ok, im going to answer only what i know for a fact.
A2: If youre going with 4x40 lcd you have 2 controls (hardware) backlight brightness and text contrast (darker lighter) and they are done by using the 100 and 100k potentiometeres on most kits that i saw
A3: All you need is the dispaly, 2 pots, and cable. conect everything and voila. Simple instalation.
A4: I use the ground from the PS. You have four wires that would connect to your Hdd, red is +5, black(there are 2) is ground and yellow is +12, so i just ran a wire to the lcd, but you can also ground it through your parallel port, both methods work.
hope i helped.
LinkBack URL
About LinkBacks
ictures@128.8.187.126/d:/newdlls
