Hi guys,
i'm running xp on intel d201gly2 with 512mb ram.
Now, when i select hybernate , the system goes down but the problem born to resume from hibernate state.
So .. i need to hold on power switch to wake-up and try to start and often it's does not work.. ( if you look, normally just a simple touch need to wake-up system...)
i have connected power switch to M1 atx so automatically switch on motherboard with +12(key).
The only way to restart machine it's to remove main power .. and just restart with a strange message "the system goes down due to a temperature problem...".. press ok and continue.
What can i do to work correctly with hibernate state, unfortunatly this intel d201gly does not support s3 mode..
thanks to all.
sorry for bad english!
