Results 1 to 3 of 3
Thread: toshiba satellite 2590 cdt question
    Constant Bitrate cubanmoses's Avatar
    May 2003
    miami/orlando
    i've been searching on the net, and i can't determine if this laptop is compatible with an lcd screen. thanks for the input.
    May 2003
    miami/orlando
    i found out i have a 15-pin connector in the back, can that hook up to lcd screens?
    from what i've gathered i can use a vga screen but they seem to be more expensive. there is one connection on the back, and it might be dumb to most of u, but i can't determine what it is, it has 9 pins. also, on the back off the laptop is an infared port, anything i can do with that?
    http://www.c1tech.com/e-3.htm
    found this, something like this can convert the vga signal to an lcd screen correct?
    Jan 2003
    Ruston, LA
    looking at the specs from toshiba, that computer only supports vga-out, so you will either need a vga lcd, or a scan convertor if you plan to connect to a composite lcd
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
