Results 1 to 7 of 7
Thread: Rugged PC Suitable for Car (Check this)
    Jun 2010
    I found thiswhile looking for a suitable small pcfor putting in my car. Not sure of prices yet. But from the blurb theyseem to be able to offer upto a core2duo fanless. Sounds interesting.
    "http://www.sumitsrl-uk.com/Products/RuggedPC.aspx"
    Rgds Yandman
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by yandman View Post
    Rgds Yandman
    Or you can look for off the shelf small PCs and run for years trouble free without paying any premium for "rugged" |-|ardware.
    It really works...
    Last edited by TruckinMP3; 03-09-2011 at 05:00 PM. Reason: atuolinks to the wiki should be optional
    TruckinMP3
    Read the FAQ!
    Jun 2010
    Rugged PC
    Hi,
    I agree,however, I've not seen any off the shelf rugged pc's this powerful at this size ?
    Maybe I'm wrong !!
    Jun 2002
    Colorado
    Hi,
    Maybe I'm wrong !!
    You missed my point... No need for rugged. - over rated, over priced, not needed.
    Off the shelf, sure because no one I know makes their own
    Small because that makes it fit in smaller places.
    I get that opinions vary ...
    TruckinMP3
    Read the FAQ!
    Jan 2008
    i agree with truckinmp3 on this one. while there might be some uses for a ruggedized pc, in most cases, the market does not involve most members of this forum.. many of the non-ruggedized components last just fine and for much, much less...
    Feb 2005
    Cali
    Stick with a laptop hard drive and you are in good shape
    I agree that there is no need for a hardened PC. I remember reading somewhere in this forum that a crash that would be strong enough to frag your hard drive would be bad enough that the condition of your computer would be the least of your worries.
    I recommend a case that will mount 2.5" laptop style hard drives (or use an adapter), as they are less effected by road shock. Or go with a solid state drive and don't worry about it. I have never had a problem in 5+ years of road computing...
    I do recommend safe and secure mounting of all your wiring and components. This will save the hassle of locating a loose connection under the carpet or in the trunk. Be sure everything is fused adequately and use correct gauge wiring. Poor wiring can lead to fires and that is a real concern...
    Cheers
    Elsewhere
    They give no indication whatsoever about what makes this PC "rugged".
    Chances are it is just a small formfactor PC in a tough-looking case with what appear to be specialized connectors.
    They will charge a hefty premium for the label of "rugged" when it really amounts to naught.
    Quote Originally Posted by Thefdog View Post
    The jury is still out on whether a laptop drive is more durable in a vehicle or not.
    When you have users with 3.5" HDDs outlasting multiple vehicles, I don't know if there is any durability advantage either way .
    SSFs, on the other hand, are a different story.
    Excellent advice!
    How about the Wiki?
