Results 1 to 10 of 13
Thread: USB devices don't always work
    Jan 2005
    I'm using an Asus EB1501 eeeBox computer for my car pc. It uses a laptop type power supply, so I'm just using a laptop car adapter to power it. I've got the following USB devices plugged in:
    Behringer UCA202 USB soundcard
    XM PCR receiver
    BU-353 GPS receiver
    Lilliput 669GL-70NP/C/T HDMI touchscreen
    Bluetooth receiver from Rii Mini bluetooth keyboard
    I don't have any power management devices at the moment, so I just press the power button to turn off the PC when I turn off the vehicle.
    When I turn it off, the USB devices stay powered. When I turn the PC back on, sometimes the USB soundcard will not be found(and I've disabled all the other audio devices). The soundcard is plugged into the back of the computer, so I can't easily just plug and unplug it, so I have to reboot until it works. The bluetooth adapter also is occasionally unrecognized, and I can remedy this by plugging and unplugging it from the front of the PC.
    Is it possible that since the PC keeps all the USB devices powered that they get out of sync with the computer? Being that the devices are always powered, even when the PC is off, I would think they'd occasionally need a full reboot themselves.
    Has anyone else experienced these sort of issues?
    I'm going to add a powered hub next, so that I can add more devices. I'll set it up to lose power when the ignition is switched off, hopefully remedying this situation.
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Yes, you are correct.
    USB devices need to be powered down during a shutdown or a hibernate for them to be recognized best upon re-start. However this is not always foolproof. U need to have good drivers for your devices to be recognized.
    There may be a setting in your laptops BIOS that will shut down USB power when the unit is shut down, but you are on the right track with a powered hub, that helped me out considerably.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Jan 2005
    Quote Originally Posted by DaveDog View Post
    Thanks for the quick reply. Unfortunately, there is no option on the eeeBox bios to disable USB power when the machine is off.
    It's not a laptop BTW. It's a small desktop, pretty much a netbook without a screen.
    Any other thoughts on this are welcome, and I'll buy a powered USB hub in the meantime to see what I can work out.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have had a few devices which don't seem to like to reconnect after a power up.
    I have solved this by using a powered USB hub, which gets power before the PC boots.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    ^^^ what enforcer said.
    I am running 3 four port self powered hubs and a dozen devices and have very few issues.
    Nov 2010
    i have a very good solution, i will post soon, when hibernate it shutdown the usb device that you set..... and wake up, it re-enable the port !!!
    its in the carpc hd, i will post soon a topic with a good tutorial!!
    was so hard to found the solution, but that now i have you will see, its very simple!!
    dont need to buy anything else
    Moderator - CarPC News Penzance's Avatar
    Jan 2010
    Tennessee
    I'm Looking forwards to what you came up with.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Sounds great! I'll be watching for it.
    Nov 2010
    yes, its devcon..... =(
    look here guys, maybe help
    http://www.mp3car.com/vbulletin/gene...ml#post1431280
  1. interesting way to install XP on cd-less/floppyless
    By gospeed.racer in forum Operating System Optimization
    Last Post: 11-11-2010, 07:55 AM
  2. No USB Devices Working Out of the Blue
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 10-17-2007, 12:21 PM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  4. USB devices die off in 20 min. HELP ?
    By anik321 in forum General Hardware Discussion
    Last Post: 08-04-2005, 10:01 AM
  5. Opus 90W w/ hardwired USB devices
    By beckkl in forum Power Supplies
    Last Post: 10-13-2004, 06:20 PM
