2 Attachment(s)
[Tutorial] Alternative way for the No Working After Hibernate/On Hibernate Resume
Here have some topics with that, but its hard to "find" this 2 programs in same time...
please, dont "look" the bad english =x i will correct it
so im here to make it easy for some guys dumb like me banghead
i use windows xp professional in the car pc with a d510mo mb. for me its a good solution... for some guys can help too, sorry for who not :pout:
1) http://www.desimonesystems.com/suspe...ateTrigger.exe
(The Program that open another when you are going to hibernate or resuming)
2) Download the HibernateTRIGGERbats.rar in topic attachment
in this file you have:
a) resumirhibernate.bat
in the file this command: devcon.exe enable USB\VID_xxxx*
b) suspenderhibernate.bat
in the file this command: devcon.exe disable USB\VID_xxxx*
3) Download the Devcon.exe from microsoft, in the attachment you have 2, one for win32 and another for win64
take the one that you need..
TO DO:
1) Install the SuspendTrigger
TO MAKE THINGS EASY, CREATE IN THE CARPC C:/ a folder called CarPCHibernate
put in this folder, devcon.exe
put in this folder, the 2 .bat files, resumirhibernate and suspenderhibernate
now we have to get the USB port that you want to disable when hibernate and enable when resume...
open cmd command line, type cd.. (2x) so you will have c:>, type cd CarPCHibernate, so you will have C:/CarPCHibernate>, now type devcon.exe status USB\* (enter)
you will receive all the usb ports...
like this image ->
http://lh5.ggpht.com/_TzuQivSQp8I/TU...ontutorial.jpg
look the 4 numbers VID_XXXX&
you need this 4numbers, look for the line that is for you touchscreen or another usb that you want and take the 4 numbers(maybe letters too)
now go to the resumirhibernate.bat (Open using one text editor like wordpad)
so you have
change the xxxx for the 4numbers of the usb that you want
eg. devcon.exe enable USB\VID_A401*
edit than save..
do the SAME with the SAME numbers in the suspenderhibernate...
now go to your desktop (if you already installed the hibernateTRIGGER, if not, so install now)
open the Hibernate Trigger.
http://www.desimonesystems.com/suspe.../hibernate.gif
in the first path, select the resumirhibernate.bat
and the second, select the suspenderhibernate.bat
Tic the Make this program minimized, than press minimize button...
Done, when you hibernate a fast CMD window will open for a second, do the command to disable and close the DOS window, and when you resume it will open another DOS window do the command to resume and will auto-close.
so be happy without ******ng non working touchscreen after hibernate
PS: it solved my problem
PS2: i use windows xp
PS3: i use BRAVIA TOUCHSCREEN (i think its a brazilian screen)
and the last, SORRY FOR THE BAD ENGLISH i will correct later, now i have to go =/
good lucky
and dont forget, im noob too =(
