Results 11 to 20 of 25
Thread: Anyone know of a USB video to Composite out device?
  1. #11
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    You would be 100% correct It was like $3 shipped, so figured it was worth a shot. It arrived yesterday, and it does not work with the USB<->VGA adapter. Now back to finding one that will work......
    EDIT:
    Ok I found one with specs that seems like it will work OK for $25. It's a Sewell PC to TV (VGA to RCA) Converter
    • Input VGA Resolution 640x480 @ 60/ 72/ 75/ 85Hz , 800x600 @ 60/ 75Hz, 1024x768 @ 60/ 75Hz
    • Output VGA\ VIDEO\ S-VIDEO signal at the same resolution
    The best part is:
    The converter sits near your PC and gets its power from your PC's USB port through an included USB-to-5V-power-tip cable. This converter takes advantage of the power current coming from your PC so as not to require an additional power outlet.
    This is perfect, as I will not need an inverter or some other way to power it in the car.
    My Fiero Build Thread
  2. #12
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Correct me if I'm wrong, but you want to display VGA on a RGB composite monitor...correct? That adapter is the REVERSE of what you want. It displays a RGB/Composite signal on your VGA monitor. I have a similar model that I onced used with a sat TV box to view the output on my VGA monitor.
  3. #13
    Jan 2008
    nope, that sewell device should work great-- i have read of a couple of other members that used it with great results:
    http://www.mp3car.com/vbulletin/newb...ompatible.html
  4. #14
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by VegasGuy View Post
    Ok, you scared me for a minute hahah! I thought maybe I acted in haste when I purchased it, and had to go look!
    No, it is the correct one. It takes VGA from a compyter to display on a TV. Here are a couple of the reviews on the product from Amazon's site:
    I use this to display karaoke words on HD screens (from a laptop to the TV).
    I needed to connect a new laptop to an older TV. The TV only has RCA inputs and the laptop only has HDMI and VGA out. This device worked perfectly to show video on the TV. Very affordable and only seconds to hook up and use.
  5. #15
    VegasGuy's Avatar
    May 2009
    Las Vegas
    It's been a long day and I forgot to wash my glasses....yeah, that's my excuse. I COMPLETELY mis-read that product description. That, and my RGB to VGA converter looks exactly the same. Sorry for the confusion.
    Cheers!
    VegasGuy
  6. #16
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    John, this is the one I used a couple of years ago. With remote and all. Worked pretty good on a 35" tube set using RCA composite input only. Plus can adjust with buttons on remote also.-------> http://www.ruby-electronics.com/stor...p_to_1600x1200 I have it up in my attic somewhere in a big, big box of PC stuff etc.
  7. #17
    VegasGuy's Avatar
    May 2009
    Las Vegas
    I realize my track record isn't all that good today, but you do realize that's only going to display an exact copy of your main monitor. You won't be able to treat it like a second monitor or desktop in any way? Just askin'
  8. #18
    May 2007
    The Sewell unit will only be getting the secondary monitor output of usb video card and running second instant of RR I believe. I think? I was only showing my unit version to compare because it has more advanced options like sizing the screen etc. for it being used for.
  9. #19
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Wow, you really are batting 'zero' today LOL. In the first posts, I explained that I am using a USB to VGA converter to use a second monitor. In the screen capture above (post #7) , you can see 2 instances of RR running on the PC. One on the left side of that capture, and the gauges, being the USB video card / second monitor
  10. #20
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Or I could just shut the hell up. Man, it's been a tough day. Good luck!
    VegasGuy
  1. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 08:35 AM
  2. Replies: 10
    Last Post: 11-20-2006, 06:14 PM
