Results 1 to 6 of 6
Thread: Using a tablet/laptop USB to trigger amplifiers remote 12v+?
    Feb 2011
    Has anyone done this by using the USB 5v to trigger a small relay to send 12v+ to an amplifier when the computer is running?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I think most laptop power supplies have a 12v trigger line available so why mess with usb? I know my P1900 supply has this and I use it to trigger the amps. It works perfect.
    Feb 2011
    Well I'm not sure the tablet I purchased will be the last tablet I'm going to use. So I would rather not open it up and hunt/peck for a 12v source to tap into. I figured using a USB port would create a modular style amp trigger circuit. The tablets DC power supply will get ACC current for charging the internal tablet battery. But to prevent any kind of turn-on thump I would rather have the amps kick on when the USB ports are activated on bootup.
    MySQL Error
    Oct 2004
    dont touch the USB 5v
    usb 5v is monitored and have specific current limits
    there are USB controlled relays out there (becarefull though some violate usb design rules for suspend)
    there is mine of course... whiuch you can purchase right here a mp3car.com (MJSG USB-IO-1)
    might do more than you want...
    and is controlled by front end application
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jan 2008
    Quote Originally Posted by PhilG View Post
    this is your best option, but you are misunderstanding what he is talking about.
    the carnetix 1900, and 2140, and the dc-dc-usb are the power supply options(there isn't many other options) that you can use for a laptop install.
    ie: these replace that power brick that is included with every laptop to charge the battery.
    all 3 of these options have a secondary +12v output that is designed with the intent to turn car audio amps on/off.
    Feb 2011
    Ah I understand now. Guess that is an option..
  1. Using a tablet/laptop USB to trigger amplifiers remote 12v+?
    By teamtreo in forum General Hardware Discussion
    Last Post: 02-16-2011, 12:54 PM
  2. Help - how to: Dsatx-->remote amp trigger
    By Kosti in forum Power Supplies
    Last Post: 12-02-2008, 07:07 AM
  3. Replies: 1
    Last Post: 09-18-2004, 04:43 PM
  4. Opus remote trigger. Amp turn on
    By live2themaxuk in forum General Hardware Discussion
    Last Post: 09-08-2004, 04:37 PM
  5. FS: Opus 90watt with Remote Trigger
    By naevity in forum Classified Archive
    Last Post: 03-29-2004, 05:47 PM
