Results 1 to 6 of 6
Thread: Help with Black Box case
    Jan 2011
    Astoria NY
    Hi all. I'm about to install my car pc into my car and i've got a question about the 6-pin connector on the Black Box Mini-ITX case
    There are six wires for the connector and I'm thinking red, black and yellow are for power, but what are the green, blue and white wires for? I know I can use them for whatever I want, but is there a specific way I should be connecting these three wires? Anti-thump is the only thing I can think of.
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Match the colors to whatever color/power scheme your power supply uses. They are all the same gauge wire, so it doesn't matter how you use them. If you don't need the three left over wires, just leave them alone.
    Jan 2011
    Astoria NY
    Its a M4-ATX - so theres only three input wires. So i'll probably just hook one up to the anti-thump and be done.
    Jan 2008
    um, will the m4+hardware even fit in the case?
    Jan 2011
    Astoria NY
    Yep. Took a bit of modding and it goes in pretty tight, but its located by the fan so things should be cool.
    Nov 2010
    Panama City Beach
    You think the M4 is a tight fit? I put an Opus 120W in my Black Box and there's absolutely no wiggle room at all. I can't even fit the fan in there. Total pita but that's one solid p/s.
    The blue wire is usually used for the remote output, in case you were wondering.
  1. Black Plexiglass Case
    By Lithoss in forum Fabrication
    Last Post: 04-01-2008, 09:39 AM
  2. Like New Black VoomPC Case
    By sinhcredible in forum Classified Archive
    Last Post: 01-26-2007, 03:08 PM
  3. Wanted: Black mini-ITX case
    By Lyzdog in forum Classified Archive
    Last Post: 02-15-2006, 02:09 PM
  4. Fs: C134 Black Case, 256 Low Pro Ddr, Pw120a, More
    By Motorcity in forum Classified Archive
    Last Post: 04-27-2004, 08:09 PM
