Results 1 to 3 of 3
Thread: HD Radio and Microphone together with Intel D945GCLF
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    I have my Intel D945GCLF set up as 4CH audio. I have a Directed HDRadio and I use a microphone for phone and voice command via Centrafuse. Now because my line in and speaker port are now my Front and Rear, I have my HDRadio plugged into the rear microphone port. I have my microphone plugged into the front audio header. So thats how everything is plugged in.
    Now it only works if I have multi streaming enabled for the front microphone and I have echo cancellation turned off. If I turn it on every time I click something my audio skips and computer locks up just for a split second when I click anything. My calls have quite a bit of echo without it. Anyone have any ideas? Or anyone have phone and radio working on the D945GCLF running quadraphonic audio? Thanks.
    MySQL Error
    Oct 2004
    how about a USB audio capture device just for the HD Radio
    i have something that would do that, then you dont need to use the line in
    if thats the issue
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2002
    Modesto, CA
    I was thinking about it. But im maxed out on usb connections, and Centrafuse is kinda finicky with USB radio. Thats why I went with line in radio input. I have seen posts of success with this board and similar setups. Hoping someone will give some feedback on how its done.
  1. help with intel d945gclf motherboard setup
    By tibimakai in forum Newbie
    Last Post: 05-31-2010, 01:02 PM
  2. Intel D945GCLF no display
    By aziz101aziz in forum General Hardware Discussion
    Last Post: 10-07-2009, 07:24 PM
  3. Can someone help me with these number? -- intel d945gclf
    By mrpeenut24 in forum Power Supplies
    Last Post: 02-27-2009, 01:35 PM
  4. VoomPC-2 Case with Intel D945GCLF
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 07-29-2008, 03:12 PM
