Results 1 to 10 of 15
Thread: SSD - very slow on XP
    Mar 2008
    Hello,
    My 320Gb 2.5" SATA drive started to fail (cross-links, random reboots) after about 2 years of being in the car..
    So I picked up a Patriot Inferno 60Gb SSD (SandForce chip) hoping it would make my system more reliable and faster.
    Well. It didn't get faster it got SLOWER.
    It's an Intel D945GCLF2 Atom based system (1Gb RAM). XP SP3 Pro
    After SSD install:
    The boot time is about 90 sec (was about 60 sec)
    Time to hibernate / unhibernate - 40 sec (was about 20)
    Time to backup the drive (12Gb of used space) - 70 minutes (!) (was 6-7 min)
    I tried the trick with partition realignment - didn't help.
    I realize that XP doesn' support TRIM and D945GCLF2 doesn't support AHCI - maybe that's the problem?
    Anyway - does anyone have a similar setup (Intel Atom motherboard + XP) with an SSD working reasonably fast?
    Am I just wasting my time?
    Thanks!
    --max
    Jan 2008
    Dartmouth, MA
    If you can, disable the paging file.
    Also make sure you install the chipset drivers.
    Trim is only an issue over time and AHCI does significantly improve the speed of SSDs, however if the SSD is slower than an HDD on the same port, that suggests something more serious is wrong.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jan 2008
    are you using a newly installed OS, or did you just copy over the old files?
    Mar 2008
    Restored a backup...
    Quote Originally Posted by soundman98 View Post
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by maxthebuilder View Post
    There's your problem. When you install a solid state drive, restoring an operating system doesn't work well. You need to re-install Windows.
    Mar 2008
    I have the newest chipset drivers from Intel.
    Paging file shouldn't slow down the boot, right?
    Quote Originally Posted by PaulF View Post
    ---------- Post added at 04:25 PM ---------- Previous post was at 04:18 PM ----------
    Could be.. Does work for some people, though.
    I tried to avoid the OS reinstall for obvious reasons. But I guess, I have to do it...
    By the way, I did do a fresh Windows 7 install on that SSD. The boot times were still bad (over 1 min). Can this be because the lack of AHCI?
    Once booted it was faster than XP in creating backups (10 times faster) but writing/reading the hibernation file was painfully slow - close to 1 minute.
    Quote Originally Posted by kegobeer View Post
    Nov 2010
    Panama City Beach
    AHCI will definitely impact SSD performance. Did you install the chipset and other drivers from the Intel website, and did you install all of the Windows 7 updates before timing the boot and other drive functions?
    Mar 2008
    -- Installed from Intel site.
    -- Windows 7 updates didn't affect the SSD performance... (I actually don't want to use W7... want to stay with XP)
    Feb 2007
    PA
    I'm running XP on a ocz-vertex 2 SSD and it boots in about 15 seconds Make sure you drive is properly aligned - here's some links
    http://www.ocztechnologyforum.com/fo...-recovery-disk
    http://www.ocztechnologyforum.com/fo...e-working-life.
    Basic guide - http://www.ocztechnologyforum.com/fo...BC-for-OCZ-SSD
    Elsewhere
    If your OS is on an SSD, you either want no paging file at all or a paging file with a static size to reduce the writes to the SSD.
    Writing to the SSD is what will reduce it's useful life, so keep it to a minimum.
    How about the Wiki?
  1. T22 too old and slow??
    By BrianC72bgt in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 04-10-2008, 09:23 AM
  2. Why so slow?
    By chvybeatsford in forum General Hardware Discussion
    Last Post: 01-30-2008, 07:32 AM
  3. SLOW that FSB!
    By eduardovdr in forum Software & Software Development
    Last Post: 05-31-2005, 09:37 PM
  4. Maybe I am slow.
    By sfay93 in forum PowerVoice
    Last Post: 10-15-2004, 11:51 PM
  5. Usb Gps Slow ?
    By BOND007BE in forum GPS
    Last Post: 12-18-2003, 05:25 AM
